Old 04-09-2005   #1
Removing the center vents?
I guess this is the first thread here, and I hope it's in the right spot. Anyway, I am looking to replace the center vents with the 3 gauge pod I have from straightlinespecialties. I wanna know how to remove these, as I guess they don't come off with a flat head, like most cars. Thanks!
-A. Swift
Old 04-09-2005   #2
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
Re: Removing the center vents?
You have to open the vent (like you would to have it blow air on you) and there are 2 screws that hold it in there. They are behind the fins all the way on the outer edges.
Hope that helps.
Old 04-09-2005   #3
hmmm..I guess I'll hafta look again. I looked for screws, but I never saw any.. Iam assuming they are phillips? I am gonna need a longer screwdriver.
-A. Swift
Old 04-09-2005   #4
Yeah, once you see them it's an easy out. If you really have issues and can't get it post up here, you could swing out to my place (Between Rogers and Elk River which isn't to far from ya) and I coudl do it for you quick. But you should be able to get it fairly easily.
Old 04-09-2005   #5
sounds good. thanks bro..
-A. Swift
Old 04-09-2005   #6
On a 1G there are no screws to mess with. There are 2 tabs, one on each side that your hold down and then you pull on the vent itself and it will pop out. Just do one side ant a time and make sure you get the one side out a little and be careful with the otherside so it doesnt pop back in.
Old 04-09-2005   #7
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
That's right. I'm sorry for the mis-information.
Old 04-10-2005   #8
lol, actually i figured it out, before I read about the tabs! Anyway, thanks guys.
-A. Swift
Old 04-10-2005   #9
same setup on the 3s, fyi..
