Old 05-13-2005   #1
dsm_98
Rear Diff.
Was wondering if a 1g rear differential would fit on to a 2g.
dsm_98 is offline   Reply With Quote
Old 05-13-2005   #2
Re: Rear Diff.
Nope, but why would you need to put one in?
Old 05-13-2005   #3
dsm_98
Re: Rear Diff.
I need to put one in because my rear axle broke and the rear diff. cover is cracked where it mounts to the frame, got a rebuild kit for the axle but broke agian when i was going to take it home.
Old 05-13-2005   #4
Wizard
Re: Rear Diff.
The rear-end itself is probably the same (internally) but the case is different because of it's mounting. 3 bolts on each side and 2 for the rear. The 2g has it's own motor mounts (like the engine mounts) for each side of the carrier.
Wiz
Old 05-14-2005   #5
Re: Rear Diff.
You might be able to just buy the cover from the dealer.
Old 05-15-2005   #6
dsm_98
Re: Rear Diff.
Thanks alot for the help. I was just wondering since that i am going to have to wait for the part or find a part like that is it safe to disconnect the drive shaft and rear differential? Make it a front wheel drive for a while by pluggin in the transfer case? Is it going to be too much stress on the transmission?
Old 05-15-2005   #7
Wizard
Re: Rear Diff.
You can't do that unless you have a welded center diff, welded VC or VC eliminator. Without one of thos items, the car will drive like it has a slipping clutch. And after a while you'll burn up your VC.
A welded or VC eliminator is fairly cheap and easy to install. No need to remove the tranny even. This can also be used for dyno's.
Wiz
