Old 10-18-2005   #1
KcGsXrated
KcGsXrated's Avatar
Drives: 93 Talon Tsi
Send a message via AIM to KcGsXrated
Post Cant get it in gear
Alright, so Super4x4 and i have been having problems figuring out why my car doesnt want to go in gear.
I replaced my Slave, and we've blead it a few times now.
Bernie thinks that there is a possibility that the shift fork is bent somehow. the throwout bearing sounds like its shot but we swapped it out with another and its still making the noise.
I Bought a used clutch and pressure plate from chengsta.
Im running out of ideas, any ideas???
~~DSK~~
Casey
93 Eagle talon Tsi fwd auto
KcGsXrated is offline   Reply With Quote
Old 10-18-2005   #2
CDeutsch
CDeutsch's Avatar
Re: Cant get it in gear
The clutch isn't disengaging (enough). What clutch and PP did you install? Has the fulcrum been messed with? Have someone watch the push rod while the clutch is pushed in to make sure it's moving the fork.
06 Evo IX RS
99 Miata
Old 10-18-2005   #3
If the clutch hub is sprung was it still in one piece? Meaning, were the springs all there and it wasn't rattling around when you were handling it out of the car? Does the fork move when you step on the clutch?
Old 10-18-2005   #4
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
I had a similar problem like this and took out my tranny 3 times in a few days (I never wanna have to do it again). But is it a new tranny? If it is, try switching out the pivot ball that the holds the fork thingy in place. Mine was too small and that kept the tranny from going into any gear at all. If its the same tranny and you just ran into the problem recently, then it probably wouldnt be the pivot ball.
Old 10-19-2005   #5
KcGsXrated
KcGsXrated's Avatar
the clutch and friction is ACT and 2600lb. The piston on the slave is pushing the arm almost to the case up against the rubber.
It is a different tranny, i got it from Nash along with the Xfer case, cables and bracket, Now that i think about it... Do you think the short throw i put in might be a reason, ill check the pivot point.
Suppositly it has an Evo shift fork and it was in perfect condition when he pulled it out, Maybe I should have bought a New clutch kit instead of a used clutch disc and PP.
~~DSK~~
Casey
Old 10-19-2005   #6
Outlaw1
Resident Redneck
Outlaw1's Avatar
I didn't say the shift fork was bent. Something is wrong with the clutch fork assembly. Bring those parts so we can get this thing out of my driveway.
'07 Z06 Black/Black 2LZ
10.48 @ 136.86 w/1.65 60'
Old 10-19-2005   #7
KcGsXrated
KcGsXrated's Avatar
Lol, I was waiting for you to chime in, my bad, i messed up ~ I have a horrible memory. It's probably from too many hatmful fluids.
Im picking up the 2 bolts from cvd, and the tps i got from Khadgar is on the cowl, in a plastic bag. Do i need anything else?
~~DSK~~
Casey
