Go Back   MitsuStyle > Hosted Support Forums > LSE Performance
Closed Thread
Old 09-13-2005   #1
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
motor mounts and sway bars
Im looking to find / buy Sway bars for a 1g awd 92 talon TSI. Also, Im looking for poly urethane motor mounts. The ones in the car are cracked up and shit so it would be a pretty good time to upgrade.
Decent quality and cheap would be awesome.
In need of a couple other things as well.
-Bshaft elim kit. ( I could have you do the front case possibly. It is sitting here waiting for the kit)
-Fuel pressure regulator ( 255 fp being used with stock 450's lol)
Possibly more to come tomorrow. If it is at all possible, I need this things by the weekend. Obviously, don't order anything unless we come up with something. Thanks Josh, John and Ryan!
-Josh
- Josh L.P.
Pimpin Dsmstyle is offline
Old 09-13-2005   #2
Re: motor mounts and sway bars
-Sway bar, stock or aftermarket?
-balance shaft elim, as in turned down shaft or the "kit" from mitsu?, Also we can weld the front case, we recommend a new front case and gears though. And we do not do this in car AT ALL, pull the motor out.
-FPR, Aeromotive regulator with a -AN adapter off the stock rail, and gauge as well.
-With the motor mounts I think you need to press the inserts in, after cutting out the stock unit.
We will PM you.
Pushit2.0 is offline
Old 09-13-2005   #3
Pimpin Dsmstyle
Br0k3N
After market sway bars.
If I gave you guys the front case, how much would it cost and how long would it take to get the shafts in and everything ready to go. I would need a decent explaination of what to do to ensure it works out correctly.
- Josh L.P.
Old 09-15-2005   #4
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
or to look at vfaq.
http://www.vfaq.com/mods/balance-shafts.html
7/25/09
slowbubblecar is offline
Old 09-15-2005   #5
Pimpin Dsmstyle
Br0k3N
I already know how. I looked at Vfaq and shit. The front case is being done professionally, so yea. Thanks anways james.
- Josh L.P.
Closed Thread
