Old 01-31-2006   #1
demon
urgent help
after I installed a 14b into my 2g I have white smoke coming out my exhaust? what can I do to fix the problem? help please
demon is offline   Reply With Quote
Old 01-31-2006   #2
Re: urgent help
White smoke is usually coolant.
How much boost are you running?
How reliable is your turbo?
Old 01-31-2006   #3
demon
Re: urgent help
The turbo was ported at qpr with no shaft play. boosting stock. Alot of white smoke coming out. Coolant?
Old 01-31-2006   #4
Re: urgent help
Let it run for a little bit, but watch your temps and your coolant level.
Is this on car start-up (Did you just install the turbo?), or did you go out and do some pulls and then the smoke started?
Old 01-31-2006   #5
demon
Re: urgent help
after I installed it. I let the car run then no white smoke after I took it around the block parked it running then alot of white smoke starting coming out.
Old 01-31-2006   #6
Re: urgent help
Well coolant does enter and exit the turbo...
Could this be a headgasket issue?
Old 01-31-2006   #7
demon
Re: urgent help
their is no coolent on the oil stick or in the radiator. I don't think it's the head gasket. I just replaced my injectors. I thought that one of my injector was stuck open but it's not the case.
Old 01-31-2006   #8
Re: urgent help
any leaks around the bolts for the coolant lines? i know mine has copper crush gaskets and if they went bad it could leak.
Old 01-31-2006   #9
demon
Re: urgent help
I'm going to take it apart to see if the washers went bad. That might be it.
Old 01-31-2006   #10
x-pride
x-pride's Avatar
Re: urgent help
Could it just be condensation from the cold weather. I know my DSM show similar symptoms on cold MN days but during the summer it totally goes away.
Old 01-31-2006   #11
TurboDomestics
TurboDomestics's Avatar
Re: urgent help
Are you sure its not the Head gasket?
Jesse seemed pretty sure, but who knows.
There wouldnt really be any coolant on the dipstick because it would just bead off, and if their was oil in the radiator it would be by the bottom. Try draining the oil and see if theres any coolant, or try draining the radiator. You can always fill it up for free at work so its worth a shot.
4G63 0, Charlie 3
