Old 03-06-2006   #1
jturg
4g64
What kind of rods and pistons do i need to bye to bild my 4g64.
jturg is offline   Reply With Quote
Old 03-06-2006   #2
Re: 4g64
I'm not familiar with byeing parts to bild a 4G64, could someone help me out too? Can I use the pistons out of my John Deere tractor and the rods out of my CAT-powered Peterbilt?
Old 03-06-2006   #3
Re: 4g64
Enough.
Old 03-06-2006   #5
Shotgun!
Totenritt
Shotgun!'s Avatar
Re: 4g64
Crower rods are pretty good. Pauter makes really nice rods...save up for Ti rods...should be about $720 a piece. By that time you will have searched and learned all you can. JUN makes the best pistons/rods/cranks I have ever seen...but the prices are crazy.
Old 03-06-2006   #6
x-pride
x-pride's Avatar
Re: 4g64
Are you asking what brand of rods and pistons or what specs are needed to build your 4g64T?
Old 03-06-2006   #7
CDeutsch
CDeutsch's Avatar
Re: 4g64
Most people use the same rods as the 4G63 and then use custom pistons. I used Eagle rods and Ross pistons in mine.
You can buy the pistons from a lot of places. Magnus Motorsports has a wide selection of pistons with various compression ratios. I wouldn't go higher then 8.5:1 for a pump gas car but that's just me.
06 Evo IX RS
99 Miata
Old 03-07-2006   #8
Re: 4g64
You dont need custom pistons (wrist pin hight) unless you are putting a 4g64 crank in a 2.0L block which would make it a 2.3L. Rods, wrist pin hight and bearings are all the same between the 4g63 and 4g64 motors. (6 bolt = 6 bolt and 7 bolt = 7 bolt.. Duh)
The 4g64 has a deck hight 6mm higher than a 4g63, there for since the 4g64 crank has a stroke 12mm larger, 6mm TDC and 6mm BDC... The pistons and rods are the same specs except for the cylinder size making the pistons 1.5mm larger in the 4g64. 85mm bore in the 4g63 and 86.5mm bore in the 4g64. Just some tech info.
Some of you know this but for others who dont...
Old 03-07-2006   #9
CDeutsch
CDeutsch's Avatar
Re: 4g64
There you go. You learn something new everyday. I started my 2.4 build in 2002 when people weren't as knowledgeable.
06 Evo IX RS
99 Miata
Old 03-07-2006   #10
jturg
Re: 4g64
So i can use 6 bolt 2.0 rods in my 6 bolt 2.4 and dont have to use offset
wirst pins/
Old 03-07-2006   #11
Re: 4g64
wirst pins/
Correct
Old 03-08-2006   #12
Re: 4g64
wirst pins/
Wiseco off sets the wrist pin to help with piston slap on warm up, Ross and J&E pistons have the wrist pin in the middle of the piston. So its a good idea to install the off set wrist pin piston the right way (arrow or dot to the front of the motor, i e timing belt side). But having the pin moved up or down in the piston to account for a longer/shorter rod, or longer/shorter stroke is not needed as the 2.4 pistons are over the shelf now. Installing a 2.4 crank in a 2.0 block would need the wrist pin moved up in the piston to account for the shorter deck on the 2.0 block.
Old 03-06-2006   #13
Re: 4g64
Pistons are off the shelf as well. 87mm, from Wiseass they're about $395.
Old 03-07-2006   #14
Re: 4g64
You must mean about ! ~ $485 or so.
Old 03-07-2006   #15
Re: 4g64
mine were $390, 87mm
Old 03-08-2006   #16
Re: 4g64
Nope. I built two 2.4's one after the other. Total for pistons with tax and shipping was $812. You must be thinking of Rosses.
Old 03-11-2006   #17
MauiBlue
MauiBlue's Avatar
Re: 4g64
Ross/Pauter enough said.
BLUE BALLZ JR.
http://img382.imageshack.us/img382/8...r3small8ez.jpg
MauiBlue is offline   Reply With Quote
