Old 03-13-2006   #1
npaulseth
Driving with a seized turbo
Car: 92 Talon AWD Auto
Mods: 3" turbo back, MBC.
Hey guys, my turbo just seized on me (13G). The car doesn't smoke or anything like that, just has no power. I am looking to drive the car to MN wednesday so I can put on my SCM61/Manifold/Wastegate from Eau Claire. Think I will run into any problems?
Thanks
Noah
Old 03-13-2006   #2
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Re: Driving with a seized turbo
Yes. You have to have some way to relieve the exhaust pressure. I believe you can burn your valves otherwise. You could take the WG arm off but I'm not sure if thats enough.
Old 03-13-2006   #3
Disconnect the boost controller and plug the line so your wastegate stays open as much as possible. You shouldn't have any issue driving it, just keep your foot off the loud pedal and take it easy getting here.
You could also remove your upper IC pipe and attach your MAS and flex pipe directly to the TB, the elbow should have about the same diameter opening as the stock turbo, about 2 1/8".
Old 03-14-2006   #4
rst95eclipse
Do this. But I'd try to find something else to drive, which would be the safest bet.
Old 03-13-2006   #5
npaulseth
Thanks guys. You have been very helpful.
Old 03-14-2006   #6
If driving it is a must, I'd disconnect the WG flapper arm (or wire it open) and stay off the gas as much as possible.
Old 03-14-2006   #7
what are you coming to MN for noah?
-A. Swift
Old 03-14-2006   #8
npaulseth
-A. Swift
To buy a manifold/wastegate/oil lines so I can install my SCM.
What are you doing on Wed? Get my text?
Old 03-14-2006   #9
If the shaft breaks you could loose all of your oil thew the turbo, which is not good. Find a ride do not drive your car.
Old 03-14-2006   #10
turbo2086
turbo2086's Avatar
Send a message via MSN to turbo2086
I'm in eau claire too. If you don't have a ride, I might be able to go.
turbo2086 is offline   Reply With Quote
Old 03-14-2006   #11
that's true noah..we pulled cher's turbo apart, and that was the reason his ic and exhaust was filled w/ oil..I'd try not to drive it..take sarah's celica you stud! put the parts on at your place..? that work?
-A. Swift
Old 03-15-2006   #12
npaulseth
Ok, here's what I did. I unhooked the wastegate flapper arm, and tied the wastegate flapper open. I also disconnected the oil feed line, and pluged the hole. I am not able to get my hands on the manifold I was hopping for anymore, so I need a way to get a wastegate mounted on my car. I am impatiently waiting on my 2G mani to get here, and possibly have the gate welded on to that.
