Go Back   MitsuStyle > Hosted Support Forums > Brookdale Mitsubishi
Old 04-23-2006   #1
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
I need 6 bolt parts
EDIT - UNSURE OF WHAT I NEED NOW. I PICKED UP SOME PARTS TODAY. DO NOT ORDER ANYTHING FOR ME YET PLEASE.
1991 Talon TSI awd. 6 bolt.
-Rear main seal ( surrounds the crank on the tranny side)
If it's possible to order the metal retainer that goes between the outside plate and the seal, I'd like a new one of those also. Mine seems to be bent up for whatever reason.
-Throw-out bearing
-2 crush washers for the water line going from the head to the turbo. The crush washers connect to the head are the ones I need.
-Thermostat housing cap
-CAS O-Ring There is an oring that fits in the groove on the cam angle sensor. This is what I need.
My dad works close to brookdale, so he will be picking these items up. So please let me know each price w/ tax included + a total so I can make it simple for both you and him when he picks up the parts. Just let me know what's in stock and what's not and we can go from there. I'll be online at about 3pm Monday.
I'd like a price check for a 6 bolt lower timing cover + upper timing cover. If it's decently priced, I'll buy them. If not, don't bother to order :P
Thanks Nick!
- Josh L.P.
Old 04-24-2006   #2
Nick G
Nick G's Avatar
Snow Storm Champion!
Drives: 94 v10 Ram
Re: I need 6 bolt parts
MD183243 $2.02+ tax rear seal in stock
md040330 $14.30+ tax rear seal case need to order
MD749998 $21.46+ tax throw out bearing in stock
mf660063 $0.82ea + tax crush gasket in stock
mb660735 $8.18+ tax radiator cap in stock
md619648 $1.76+ tax oring need to order
md141454 $76.78+ tax up cover in stock
md141457 $36.74+ tax low cover need to order
all of it after tax $173.47
let me know what you want to do.
thank you!!!
Nick
Nick G is offline   Reply With Quote
Old 04-25-2006   #3
Pimpin Dsmstyle
Br0k3N
Are you sure you don't have those prices backwards? The lower cover should cost more I'd think :P I don't need either of these yet.
Is this the smallish metal peice that the rear main seal seats into? If it is, you can order this as well. I have a feeling I will have a little oil leak problem there :P There should be 3 peices listed for that portion of the motor. One is the rear main seal, the small metal retainer that the seal seats into, and the exterior case that bolts to the block on the outside of the seal & retainer.
mf660063 $0.82ea + tax crush gasket in stock (x2)
thank you!!!
Nick
These are the parts I need. Order whatever isn't there and I'll be good to go. What day should everything be ready? I'll have my dad swing by and pick them up for me whenever everything is there. I could also use a final price so I know how much cash to give him
- Josh L.P.
Old 04-26-2006   #4
Nick G
Nick G's Avatar
Drives: 94 v10 Ram
I missed the rear main,sorry.MD619648 $18.82
All of it after tax $49.76
try to get it all here friday.
Ill pm when in
thank you!!!
Nick
Old 04-27-2006   #5
Pimpin Dsmstyle
Br0k3N
lol now i just got confused. What exactly would these be then?
- Josh L.P.
Old 04-27-2006   #6
Pimpin Dsmstyle
Br0k3N
This is in stock ? To be clear I need the "rear main seal" ( seal surrounds the crank to prevent massive oil leak) and I need the small metal bracket that the rear main seal presses into.
I wish there was a way for me to pick these up to make sure everything is fine.
Is there a place for me to look up these part numbers so I could make sure everything was fine? I don't want to have you order something I don't need because I realize you don't want any dead inventory and I don't want to buy something I don't need!
- Josh L.P.
Old 04-27-2006   #7
Nick G
Nick G's Avatar
Drives: 94 v10 Ram
by chance do you have a fax?
Old 04-27-2006   #8
Pimpin Dsmstyle
Br0k3N
! I don't have fax. I can't better describe the stuff =/
md619648 $1.76+ tax oring need to order ( CAM angle Sensor)
These are obvious parts I need. Now I also need the "rear main seal and retainer" These parts should be listed together. The rear main seal seats into the retainer. Makes sense?
- Josh L.P.
