Old 06-27-2006   #1
gstjoker
gstjoker's Avatar
Question Strut Bar
I've been thinking about getting front strut bars for my 96 GST. Do any of you know if there's any difference from other strut bars to the ones on ebay? Such as durability or its performance on the cars? Any recommendation or advice would be great. Sorry for the fact that I don't know much about this.
Old 06-27-2006   #2
Re: Strut Bar
Ractive makes very stiff yet cheap bars. There can be a difference, but probably not a whole lot.
Old 06-27-2006   #3
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: Strut Bar
Yea I used a cheap ebay one on my last car and it worked fine. Couldn't feel or notice any differance though.
pics or gtfo
Old 06-27-2006   #4
Re: Strut Bar
Was all the weight of your car on the frame rails when you installed it? I installed mine on my Laser simply because I was sick of it laying around the garage. When I get around to installing it correctly, I will put my car on a lift.
Old 06-27-2006   #5
Shane55113
Now 20% less Racist
Shane55113's Avatar
Re: Strut Bar
I don't understand what you mean? How would it be different if you installed it on a lift instead of on the ground? As long as its standing still there is no load on the top of the strut towers, so if anything it would be better to keep it off a lift.
Just to chime in here, if you want a strut tower bar that would work really well just look at the stock one from the Eclipse GT, it connects to both strut towers and to the fire wall. That is a good design.
Old 06-28-2006   #6
Re: Strut Bar
False. When your car is on the ground with the suspension loaded, the weight of the vehicle is placing an upward bending moment on the entire chasis of the vehicle resulting in chasis flex. With the car on a lift, the weight of the suspension will place a downward bending moment on the chasis but this is much less significant that the entire weight of the vehicle. So, to compensate for the upward bending moment cause by the weight of the vehicle, the proper way to install a strut tower bar is with the car supported by the frame only. Ideally, one would install strut bars with the suspension, brakes, and wheels removed but generally that's not realistic.
Old 06-28-2006   #7
Re: Strut Bar
I agree. If I ever get around to it I'm going to design a strut tower bar that links the struts and the struts to the firewall. Check out the 1993 Archer Racing Talon:
More information about the car:
http://www.dsmtuners.com/forums/showthread.php?t=222227
Old 06-27-2006   #8
Re: Strut Bar
FWD's (especially 1G's) have a lot more chassis-flex than the more well braced AWD's and respond more noticably to strut bars.
Old 06-27-2006   #9
94talonawd
94talonawd's Avatar
Re: Strut Bar
Its all the same. All it is is a metal bar. Heck you can just take a pipe and make one.. haha
SOLD
94 Talon AWD
Big 16G
SAFC-II
99 Civic D16 - EVO3 16G - Hondata S300 - Xenocron 4bar@21PSI - RC750cc's - Eagles/Vitara - Compcams
12.3@114, 1.81 60ft
-On it's way to 11's....
Old 06-28-2006   #10
Re: Strut Bar
There are differences, mainly in the mounting brackets. Jakey is right, at least get your front tires off the ground to unload the suspension when you install it. I installed mine with the car resting on the ground, drove it, came home and reinstalled it with the front tires jacked up and it made a difference. Also, tighten the bar so it pushes out, not pulls in. Do not tighten any of the mounts until the bar is adjusted tight; this will prevent any flex room in the bar to provide the stiffest bracing possible.
Old 06-28-2006   #11
Re: Strut Bar
I believe Neuspeed makes a bar that connects the strut towers with the firewall.
Old 06-28-2006   #12
Re: Strut Bar
Happen to have a link? I can't find anything on the Neuspeed website except for Honda/Acura and VW/Audi products.
Old 06-29-2006   #13
tim
tim's Avatar
Re: Strut Bar
I didnt know Neuspeed made one for DSMs but the VW and Honda one is the same type that would give the best results on a DSM. Jakey has the right idea. The ideal situation for any strut bar is to have it installed with no load on the suspension. The fact that a unibody car gets most of it's ridgitity(sp) from the firewall would only make sense to have the strut bar connect to it.
Old 06-28-2006   #14
Re: Strut Bar
I don't have a link, but I know for fact they made one for the 2G and am pretty sure they made one for the 1G. Check www.nopionline.com and www.hopupracing.com
Old 06-29-2006   #15
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
Re: Strut Bar
Would it a good idea to get a sturt bar for a Gst? Or is it somthing you would only need if you are putting down big WHP?
Tyler Aherns
-USN-
Old 06-29-2006   #16
Re: Strut Bar
YES! Have you read this thread at all?
Old 08-09-2006   #17
Re: Strut Bar
Do rear strut bars help as much as front ones? I didn't see any mention of them in this thread.
Old 08-10-2006   #18
Re: Strut Bar
They are totally pointless on 1G FWD cars, but all other models should benefit at least a little bit from them.
Old 08-10-2006   #19
Re: Strut Bar
How about anti sway bars? Much help there?
P.S. I don't know hardly anything about suspensions
Old 08-10-2006   #20
Re: Strut Bar
HUGE difference, the Suspension Techniques rear antisway bar I put on my 1G FWD made more of a difference that my AGX/GroundControl setup did.
