Old 08-01-2006   #1
munster000
steering wheel shakes while driving.
I can't understand why my stearing wheel shakes. I notice it the most while driving down the highway. Any ideas?
munster000 is offline   Reply With Quote
Old 08-01-2006   #2
Turbocharged
Re: steering wheel shakes while driving.
If it gets worse when you brake, your rotors are warped.
If it gets worse the faster you go, you need to get your wheels balanced.
You may want to check the tie rods for any slop as well.
2.4L g4cs, 8.8:1 compression, arp hardware, eagle rods, wiseco pistons, 50 trim, TRE transmission, SBR 3500, 880's, DSMlink, methanol injection, FP2 cams, ported 1g head, spearco FMIC, walbro 255, ect.
Turbocharged is offline   Reply With Quote
Old 08-01-2006   #3
munster000
I'll check and see if it gets worse when I go faster. I hope thats the prob. Maybe I hit something and bent a rim.
Thanks guys.
Old 08-01-2006   #4
More than likely its your wheels needing to be balanced, do that first and go from there.
Old 08-01-2006   #5
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
CV joints could be shot.
Take her to the limit!
Old 08-01-2006   #6
I am almost sure it is tie rod ends. DSM's chew them up pretty fast. Ball joints are also possible. Jack the car up and jiggle the wheel top to bottom, if it moves it is the ball joints. Now do the same side to side, if it has play, it is tie rod ends. If it does both, then it may also be a wheel bearing.
Old 08-02-2006   #7
munster000
I'll check the tierod ends tomorow. I did notice that the faster I go, the worse the shaking is.
Old 08-02-2006   #8
munster000
ALso, I just had goodyear put on 2 new wheels on the front. I assumed they balanced them properly.
Old 08-15-2006   #9
iceminion
iceminion's Avatar
er....which goodyear, chances are unless you got me to do em they are fucked, goodyear is going down the tubes
building a 3000GT AWD Turbo.
Old 08-19-2006   #10
earthwonder
I've had the same thing happen to me and it ended up being a passenger side lower control arm ball joint.
earthwonder is offline   Reply With Quote
