Old 08-13-2006   #1
Can anyone tell me what this is?
Hey when i pulled off the tranny this part fell out, Im not sure what it is or where it goes. A couple ideas i thought it may have been was somewhere off of the clutch.
Please Help asap.
Old 08-13-2006   #2
blageo23
AWD4G64
blageo23's Avatar
Re: Can anyone tell me what this is?
Looks kinda like the pin for the flywheel thats on the crank.
Old 08-13-2006   #3
yeah i just looked at ACTs site and thats what it looks like.
What do these pins do? Would it cause my clutch to not fully disengage?
Old 08-13-2006   #4
You sure thats not an alignment pin for the tranny to block?
Old 08-13-2006   #5
blageo23
AWD4G64
blageo23's Avatar
The pin from tranny to block are hollow because a bolt goes through it. Its either the alignment for the clutch PP to flywheel or flywheel to crank.
Old 08-13-2006   #6
This really sucks because I just put in the tranny completely and realised that im having the same problem as before i broke the tranny. Where the clutch will not fully disengage. SO if i put it on jack stands and start the car and put it in gear it goes fine but if i push in the clutch and tap the break it makes a loud squeeling and then dies. so i think i may have to take out the tranny once again and see whats going on with the clutch now. FUCK ME i am hating life, that tranny was a bitch to put in and now i gotta do it all over again.
Old 08-14-2006   #7
First thing I thought of was it's the spider gear shaft in the differential, especially since it's all beat to hell.
Old 08-14-2006   #8
blageo23
AWD4G64
blageo23's Avatar
I swear the spider gear shaft is WAY smaller then that. The problem you could be having is a non adjusted clutch pedal. Maybe get an extended slave cylinder rod(which I happen to be selling).
Old 08-14-2006   #9
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
We bought one a long time ago when QPR was selling them and it semmed to be useless. We had more ploblems with it than without so we took it out right away.
7/25/09
Old 08-14-2006   #10
Looks like one of the dowel pins on the flywheel that lines up the pressure plate.
Old 08-14-2006   #11
Old 08-14-2006   #12
i dont think the extended slave cyl rod will do much good. it seems to be pushing the fork just fine. its something in the clutch. I have the master cyl adjustment all the way out. and i bled the clutch fluid completly.
Old 08-14-2006   #13
I just had a clutch disengagement problem as well. New Master Cylinder cleared that problem right up. I had my old rod adjusted all the way out, and it was still not fully disengaging, making it real hard to shift.
Old 08-14-2006   #14
blageo23
AWD4G64
blageo23's Avatar
But the clutch cant disengage if the fork isnt moving far enough. Id say swap out the master cylinder and slave while your at it and see if that helps. Id say that this is not clutch related its most likely the master, slave or TOB.
Old 08-14-2006   #15
Theres no fluid leaking from the master cylinder though or even the slave cylinder. Could it still be bad? It seems like the slave cylinder is pushing the fork all the way due to the fact that i cant push it any more. Ill try tonight to maybe put a spacer in that and see if it pushes it farther. Im so glad i didnt start taking out the tranny last night, if its this i will run around naked in the streets.
Do you really need the dowel pin in there? will it cause any problems nessesariy?
Old 08-14-2006   #16
I can just see Tom pushing on the clutch fork with his thumb to see if it moves farther!
It does sound like the clutch is just dragging. Are you sure you bled the system properly?
Old 08-14-2006   #17
Yeah jet, actually after i posted that i was like hmmm... i prolly wouldnt be able to push that with my thumb too much. lol
Old 08-14-2006   #18
Ahhhh, classic Tom! Trying to push a 2,000 lb pressure plate with your thumb
Old 08-14-2006   #19
Maybe I missed it, but what exactly is making you think the clutch isn't fully disengaging? My situation was, I could shift through the gears just fine with the car off. But when I turned the car on, it would sometimes grind (sitting still in neutral), and sometimes go in, sometimes not go in. Figured it was the clutch not fully disengaging. Couldn't adjust my rod any further, and saw some fluid leaking inside.
Old 08-14-2006   #20
blageo23
AWD4G64
blageo23's Avatar
Ju-on read post #6.
There could be a inner leak or something causing it to not have all the pressure. I was missing the pin on the crank and they told me not to worry about it.
