Old 08-28-2006   #1
bmikkalson
2g head bolts reusable?
Are the head bolts on a 2g turbo reusable?
bmikkalson is offline   Reply With Quote
Old 08-28-2006   #2
Re: 2g head bolts reusable?
No, buy a new set from mitsu. Torque to yield bolts for the win.
Old 08-28-2006   #3
Black97civic
35mpg
Are there really any stock head bolts that aren't stetch to yield?? I know just about every car I have ever read about or worked on said to replace with ARP's or get new head bolts due to the stretch to yield factor.
Old 08-28-2006   #4
The 3000gt's are re-useable but I never do.
Old 08-28-2006   #5
1g head bolts should be re-usable but if you want to run over 20psi ARPs are a cheap upgrade.
Old 08-28-2006   #6
ARP's are definitely re-useable.
Old 08-28-2006   #7
bmikkalson
My car is not modified at all, so the performance aspect is not realy a factor for me. So ok to reuse????
Old 08-29-2006   #8
Why is this such a difficult concept?
Old 08-29-2006   #9
No.
Old 08-29-2006   #10
silow_gsx
$80 can save a lot of headache.
silow_gsx is offline   Reply With Quote
Old 08-29-2006   #11
NO. once they are torqued down they STRETCH (yield). if you slap already stretched bolts back onto your engine, dont be surprised if and when your headgasket blows.
Old 08-29-2006   #12
Why are so many DSMers such cheapasses and aren't willing to spend $80 in order to keep their engines running longer than 3 weeks?
Old 08-30-2006   #13
rst95eclipse
I've found that they are reuseable. Not to hold down the head. Rather to hold the engine on a stand while you work on it. I did however have to use some washers to make it work.............................Hope that helps.
Old 09-10-2006   #14
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
Don't reuse headbolts..........Once they're torqued to spec and taken off....they aren't suppose to be used again. Aftermarkets can be different.
