Old 09-13-2006   #1
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Squeaking from Valve Cover/PCV Valve Area
I recently changed my PCV valve and a week or so after that I started to get this continuous squeaking from that same area whenever the car is running. I thought the PCV valve was defective so I purchased another one and the sound still persists. I can't pinpoint the sound exactly but its somewhere in the vacinity of the valve cover/PCV valve area. The funny things is, it will squeak for a few seconds even after I turn the motor off like it's something internal stopping with all the internal parts. And also, I disconnected the hose for the PCV valve once just to see and the sound was barely audible. Anyone have any ideas what this could be?.. I hope it's not something internal fudging.
Car is a 97 GSX, 110,800 miles, rebuilt manual trans, 2600 clutch, mbc, catback exhaust, intake, bov.
Old 09-13-2006   #2
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: Squeaking from Valve Cover/PCV Valve Area
are you sure changing the PCV triggered it? When you pulled the PCV valve out, did it come out as one piece or break apart? Also, try removing the pcv and letting your car run, see if it still makes the same noise.
Style's automotive engineer
Old 09-13-2006   #3
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Not 100% positive changing the PCV triggered the squeaking noise but I never had that noise before then. It came out fine as one piece, I will try running the car without the PCV valve when I get a sec. Thanks.
Old 09-13-2006   #4
s1ngletracker
Drives: A BMW
also, try taking your oil cap off and listening while the car is running to see if the sound is any louder.
Old 09-13-2006   #5
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Ok so I took out the PCV valve and let the car run and I still hear the squeaking but not as loud. When I tried to hear exactly where was coming from, it looks like it is coming from between the intake manifold and the fuel rail. I have no idea what would squeak in that area.
Old 09-13-2006   #6
s1ngletracker
Drives: A BMW
injectors.
Old 09-13-2006   #7
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
injectors.
Injectors squeak can squeak when they go bad? SOB.. Time for new injector(s) I guess.
Old 09-13-2006   #8
Leaky seal? Start wiggling the rail and injectors to see if the noise ever stops or changes.
Old 09-13-2006   #9
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
I will try that as well, but I gotta run to class so I will post my findings later. Thanks for the help guys.
Old 09-13-2006   #10
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Wiggled everything in that area.. nada. I guess maybe it is one of the injectors. I'm going to get the injectors checked tomorrow.
Old 09-14-2006   #11
I'm not sure he meant the actual injectors, rather he meant what S2kracka said? I don't think I've ever heard of fuel injectors squeaking when going bad. But could be wrong.
Old 09-14-2006   #12
s1ngletracker
Drives: A BMW
I dunno... it could be the injectors, though i have never heard of them squeaking when going bad. You said it was from the fuel rail/IM area, thats about the only thing with moving parts around there...
How is your car running? if its running fine then i doubt its the injector actually going bad.
Try removing the rail, look at all the seals, oil up the O rings, and reinstall it.
Old 09-14-2006   #13
REPLACE all the seals, gaskets, and o-rings.
Old 09-14-2006   #14
s1ngletracker
Drives: A BMW
IF they need it. No use spending unecessary money. If they have cracks or are dried out, then you need to replace them.
NOt everyone is made of money
