Old 10-21-2006   #1
How Does Sidewall Affect Handling?
Would there be that big of a difference in handling in a same width 16" wheel/tire versus a 17" wheel/tire (Assume same wheels/tires, just differnt "profile"). I've always wanted 17s for a) looks b)handling and c) room for BIG BRAKES! After I put on my stainless lines, I like the brakes so much that with a better pad I'll probably have all the braking ability I want. So 17"s almost seem like a waste of money... Then I'd almost like to get some lightweight 15" rims if I'm gonna use the stock brakes. Hmm, opinions anyone?
Old 10-21-2006   #2
Re: How Does Sidewall Affect Handling?
Sidewalls will effect the handling greatly. Some tires have stiffer sidewalls than others. To offset a softer sidewall you can just up your tire preasure. If your main purpose is to build a 1G than can handle get some nice lightweight 17's. I had the Baer 13" track-kit and highly recomend them, great setup with some Porterfield R4-S pads. Have you removed your front bumper support yet? That saves a lot of weight over the front wheels and can improve turn-in greatly.
Old 10-21-2006   #3
Black97civic
35mpg
I read an article where they track tested a car with 15, 16, and 17" rims on the same car. The 15's were the slowest, and held the least lateral g's, the 16's had the fasted average time, and were neck and neck with the 17's on the skidpad, and the 17's had the fastest lap overall, but the average was slightly below the 16's. All of the lap times were within .5 to .75 seconds, and the skidpad was withing a couple points, nothing major.
All of the quarter mile times were within .1 second too, so basically, whatever you can afford, and looks best to you is all that really matters.
Old 10-21-2006   #4
Thor06
11 Seconds to Freedom
Thor06's Avatar
I would go 16's and stiff sidewalls. Best of both worlds.
What is this bumper support you speak of?
Old 10-21-2006   #5
The 35 lb. hunk of metal that hangs off the front of the car. Remove the front bumper cover and its held on by 4 bolts I think.
Old 10-23-2006   #6
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
3 bolts on my car.
Does that effect anything other than crash safety?
Old 10-23-2006   #7
All it does is hold up and support the bumper and making crashing safer.
Old 10-24-2006   #8
...for benefit glorious nation kazakhstan.
As for sidewalls, as these guys:
Old 10-21-2006   #9
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
The type of tire matters way more than tire size. If you want something that really sticks get some Azenis in any size and be done.
Old 10-21-2006   #10
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
I vote 17's. If the performance is similar, may as well go for the better looking of the two
-David C.
Old 10-23-2006   #11
On my last car, I had 16" rims with BFGoodrich Gforce t/a KDW, and that was my only handling mod and it handled perdy good. If/when I get rims, I am SET on the Falken Azenis RT-615, I've heard awesome things about those tires. I was kinda looking at 17" Rota Subzero's as well. (Haha, I wish I could have some SSR/Work/Volk with some Pirelli P Zero Corsa's)
Old 10-24-2006   #12
17's will help on turn in, other than that it won't help a lot. Like CVD said, the tires make a much larger difference.
Old 10-24-2006   #13
Tire PSI is also a very important consideration along with what actual tire you choose.
Old 10-24-2006   #14
Ahh, well then I might just get some better tires for my stock rims. The previous owner did an awesome job PAINTING them gunmetal. I've gotten many compliments on the stock rims, and they're growing on me Not wide enough tho :/
Old 10-24-2006   #15
Going to a wider wheel was the biggest benefit I have seen. It gets rid of a lot of sidewall flex.
Old 10-25-2006   #16
A friend has some black powdercoated FD Rx7 wheels he might want to get rid of...
Old 10-25-2006   #17
Those are light and wide.
Old 11-07-2006   #18
91autoeclipse
1. I'll go 17's.. but it has to be leight wheels.. can't be more then 18lbs.
2. Better looks.
3. Less sidewall.
Base on this I'll take the 17's
91autoeclipse is offline   Reply With Quote
