Old 11-07-2006   #1
91autoeclipse
dash and interior lights?
I have a 91 auto GSX.. I have 3 electrical problems.
1. When I open the drive door, the key hole and dome lights don't come on. Only comes on once in awhile. Opening the passenger side door the key hole and dome light never come on.
2. My radio light comes on onces in a while..
3. My temperature gauge is at Zero.. no matter how hot it gets.
I checked the thermostat connection.. looks fine. checked the wires and it looks fine. Is there someting I'm missing?
some help would be great.
tia,
91autoeclipse is offline   Reply With Quote
Old 11-08-2006   #2
91autoeclipse
Re: dash and interior lights?
So no one can help me with these problems
Old 11-08-2006   #3
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
1. Check your door switches the ones with the rubber covering.
2. The Radio is on its way out.
3.Replace the sensor that is for the gauge, and data log it to make sure the engine temp sensor works.
Take her to the limit!
Old 11-09-2006   #4
If his car starts and runs fine the ecu should know what the coolent temp is, the temp gauge sensor is the one wire sensor on the front bottom right of the Tstat housing, the wires around there become brittle and break a lot.
Old 11-14-2006   #5
91autoeclipse
bottom right side of the thermostat.. so I was looking at the wrong one..
that wire is broken and i can't even see where that wire went too..
The door sensors are all pushed in.. and it needed some oiling and adjustments,.
this helped a lot..
thanks..
tsua
Old 11-14-2006   #6
Glad you are getting your problems worked out...aren't DSM's fun
