Old 11-21-2006   #1
AEM EMS What Sensors Needed/Not Needed
I want to clean up the engine bay of wires and sensors. Im running AEM EMS with GM MAP sensor and GM IAT sensor. What sensors/soliniods can I get rid of with AEM EMS? Im pretty sure I can get rid of the EGR and emission soliniods. What else can I get rid of?
Thanks,
Mike
Old 11-21-2006   #2
Re: AEM EMS What Sensors Needed/Not Needed
Anything you want.
I would recommend to keep coolant temp, knock, cas/cam, IAT,MAP.
Everything else can be ditched, unless your particular vehicle uses the thermostat housing to control the fans via a thermocoupler. Then you might have to do some trigger wiring, but you can delete those as well if you do the wiring.
Old 11-21-2006   #3
Well thats cool, Then there isnt much wire in the engine bay. Im trying to make the underhood look really nice and I think that deleting the bulk wiring will help out alot.
PS: this is post #1000 for me
Old 01-31-2007   #4
So here is what I think Im keeping...
Brake fluid level
Crank sensor
Cam sensor
Coolant temp
Coolant light
IAC
Oil press
Oil light
MAP
IAT
I just read that the AEM doesnt really look at O2s. So Im going to eliminate the front one and the back one is being swaped out for a AEM wideband controler. Does that sound good? Any sensors you see here that I would need or some that could be eliminated?
Thanks!
Old 01-31-2007   #5
You will want to keep TPS and knock. Idle control is extremely nice too. Also save the stock boost solenoid wiring for hooking a GM boost solenoid to.
Old 01-31-2007   #6
Thor06
11 Seconds to Freedom
Thor06's Avatar
Dont you want the wideband up closer to the turbo?
Old 02-01-2007   #7
In terms of sensor performance, does it matter where the wideband is placed in the exhaust travel path?
Old 01-31-2007   #8
according to the AEM install it says to have it "18" away but if you are planing to be running a turbocharger running at high RPMs for a extended period of time or running leaded gas it should be at least 36" downstream"
Yah I forgot about the TPS and Knock, I planed on leaving them. and I have the GM BCS on there wired up alread.
Im thinking about moving up to the AEM sensors, IAT, 5Bar, BCS.
Old 02-01-2007   #9
What is stated in my above post is what AEM recomends
Old 02-02-2007   #10
I run mine in the stockish position and it's fine. It is recommended to run it farther downstream because they're not as robust as a regular 02 sensor.
Old 02-02-2007   #11
Now from you profesionals...
Right now I have the GM sensors(MAP, IAT, BCS)
Would I benifit in any way by switching to the AEM sensors? I kinda wanna go with the AEM MAP sensors because of the way its set up(threaded in)
Old 02-02-2007   #12
AEM vs GM should be the same, pending what the sensor can read, 3bar vs 5bar etc.
Old 02-02-2007   #13
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Like you stated, the MAP sensor is in a different/more convenient format (IMO), but essentially they're going to read the same. I'm not too keen on putting GM parts on anything, but that's just me. I preffer having a trusted aftermarket name over parts that come in stock cars for items like these. Once again, only my opinion though
Old 02-02-2007   #14
The AEM MAP sensors are laboratory grade, while the GM MAP sensors are, um, 80s GM grade. But they still work fine. Only being able to read up to 29psi with a GM 3 bar isn't the most realistic setup for a DSM though.
Old 02-02-2007   #15
We just use AEM map ither 3.5 bar or 5bar and the AEM IAT sensors, never had a problem. 80's GM grade, lol.
Old 02-02-2007   #16
What about the IAT? GM or AEM?
Old 02-02-2007   #17
I haven't heard any complaints about the GM IAT. Mine works great as well.
Old 02-02-2007   #18
Does anyone know who makes the AEM and GM sensors? It'd be interesting to know the resolution of each.
Old 02-03-2007   #19
The AEM MAP sensors were made by Kavlico, I don't know if they still are.
