Old 01-23-2007   #1
rst95eclipse
Torque Specs
My Helms manual isn't giving me torque specs for the bolts on the tensioner (2), tensioner arm (1), motor mount (3), oil housing (5), and idler pullies (1 bolt for each). If you have this knowledge, please post up. In ft/lbs not in/lbs please.
Thank you.
Old 01-23-2007   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Torque Specs
Timing belt tensioner = 204 in/lbs
Timing belt tensioner pully = 420 in/lbs
Oil Filter housing = 132-192 in/lbs
Dont have any info on the idler pully and the only thing I can find on the motor mount bolts are "tighten them securely".
bahaha
Originally Posted by shoutbox
Old 01-23-2007   #3
rst95eclipse
Re: Torque Specs
bahaha
Do you think I'd be better off welding everything to the block?
Old 01-23-2007   #4
Re: Torque Specs
I hate dividing by 12 too.
Old 01-23-2007   #5
rst95eclipse
Re: Torque Specs
It's not really the math. I'm just thinking that everything to do with timing is going to be in ft/lbs. Plus my torque wrench is only in ft/lbs, so I might as well keep everything "standardized," so I don't f*ck anything up.
Old 01-23-2007   #6
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Torque Specs
Lets confuse him... 1 in/lb = .833333333 ft/lbs.
You do the math! Lazy bastard!
Old 01-23-2007   #7
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Torque Specs
YES! Definately.
Knowing you... You will! Ha.
Old 01-23-2007   #9
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Torque Specs
I gave you the right answers... Just do the math. Meathead!
Also, the oil filter housing bolts are in IN/LBS.
Old 01-23-2007   #11
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Torque Specs
I am an asshole but not that big of one! I would atleast give you the right info.
Old 01-23-2007   #13
Re: Torque Specs
My big torque wrench only goes down to 20 ft/lbs, so anything under 20 ft/lbs or 144 in/lbs I had to use a torque wrench that was in in/lbs.
