Old 01-23-2007   #1
gsxer
Another DSMlink question.
Well ive been searching and havent found anything out about my question.
My question is if I run a DSMlink would I still need to run my Apexi AFC-2??
Would I need to have run the 2g MAS still?
-yinchinzhong
MODS:
6-bolt swap
ARP hardware
QPR EGR Block off
BS elim kit
'90 oil filter housing
small 16g turbo
fmic
ported 2g exhaust manifold
255HP fuel pump
2.5" dp, w/ dual 3" resonator
Apexi AFC-2 (changing to dsmlink)
650 injectors
polished 1g fuel rail
MBC
aluminum radiator
gsxer is offline   Reply With Quote
Old 01-23-2007   #2
Re: Another DSMlink question.
No you won't need the AFC any longer. You will need some means to meter airflow though, so you can't just ditch the MAS unless you have another means of metering air. The 2g MAS will be absolutely fine for your setup though, just keep it.
Old 01-23-2007   #3
Exactly as Brandon said.
Old 01-23-2007   #4
gsxer
alrighte thanks guys
