Old 02-16-2007   #1
EvilEvo
My Winter Project....
Here it is from the start and finish (Sooner or later at least):
Here is a link to the other post: http://forums.evolutionm.net/showthread.php?t=251529
This started out as a simple build-up for next season until a few of us got drunk... that is when it really started...
So I tore it apart a little bit.... I decided I needed to obviously save some weight so that is when the next phase began....
Here is how I started to remove extra uneeded weight:
-Tim Russell
EvilEvo is offline   Reply With Quote
Old 02-16-2007   #2
EvilEvo
Re: My Winter Project....
-Tim Russell
Old 02-16-2007   #3
EvilEvo
I decided my old 10 point mild steel cage was too heavy so obviously it had to go:
I figured it was easier just to remove the floor
Obviously I needed to replace the cage and floor so that was next....
-Tim Russell
Old 02-16-2007   #4
EvilEvo
I also figured I would FINALLY need some slicks to help hook the car up considering I used to spin em badly and now it should weigh around 1,000 lbs less so I picked up these little guys....
And considering the size of the rear slicks I figured I wouldn't need much for the front so I settled for these....
-Tim Russell
Old 02-16-2007   #5
EvilEvo
Here was one of my early cad drawings of what I wanted to do and make sure I pass the 25.1 spec:
The geometry of the car was slightly different than I expected so I did have to make a few changes. I also made a few different versions on the cad drawing to make it lighter or stronger or both but you get the idea.
The body panels have been mocked up with a jig so they will be straight. I have braced the body so it is reasonably straight as well. It will need final touches once I get ready to bolt it to the new frame.
It will still obviously be the 4G63 running a GT4202 or something similair. It will run Methanol (and Nitrous eventually). The test motor is a decently built one that I plan to shift at around 10.5k. Using a 3 speed mockup design I expect the car to top out around 180-200 given enough go-go juice and time.
This season it will mainly be testing and tuning it. Ive never driven a fast RWD car moreless this damned thing so it will need some time to get worked it but I will make it to a few national event for sure next year. The shootout is garunteed (sp?). I am thinking one of the Nopi events would be fun... havent decided for sure yet. The car will be certified for 7.50 seconds or quicker from SFI and I will be licensed to run it so I can enter any sanctioned event. It will have all safety requirements.
-Tim Russell
Old 02-18-2007   #6
What did you build your model in, Solidworks or Pro/E? Run any FEA load simulations to see how your cage is going to behave?
Buschur has always been pretty nice to me and AMS has always hated me since my intake manifold design. They tried to belittle me and throw long words at me to make it seem like thier intake manifold was so great... then I showed them what CFD and engineering could provide and they pretty much shut up.
Care to expand upon the "CFD and engineering?" What'd you run CFD models in, Fluent? As soon as I can afford it, I have some OEM parts that I'm going to send off to get CAD models of and hopefully then run some CFD models.
Old 02-19-2007   #7
EvilEvo
I used solidworks to make the model proto-type. I use FloWorks for the lighter CFD stuff and Fluent for the more extensive stuff. Yes I ran load simulations but I honestly dont know how accurate they are considering that is not even the exact design on how it turned out. It is also hard for me to find out exactly where the load would be placed and at what direction, etc, etc... I mainly used the load testing part on small certain clusters. Another reason I couldnt really do much of the load testing is the way I stuck all the piping together. I did it in a way that none of them are technically connected in solidworks.... that way I could make a parts list with lengths and even print out the coped cuts for each pipe should I want to.
If you want let me know what the parts are and if it isnt too complicated Ill draw them up for ya.
-Tim Russell
Old 02-19-2007   #8
Hopefully the FEA will at least isolate the major stress concentration areas so you can address those.
That's the problem; they're rather complicated. I plan to send them to Advanced Design Concepts in Pewaukee.
Like I said before, they got really pissed off at me after the whole intake manifold thing so since then I have not been awfully found of them.
Where is this thread at?
Old 02-16-2007   #9
EvilEvo
A few more pics:
-Tim Russell
Old 02-16-2007   #10
EvilEvo
-Tim Russell
Old 02-16-2007   #11
EvilEvo
As far as the aero, yes it is a horrible platform to build a drag car of this magnitude but it is one of a kind and its mine. My estimated ride height will be roughly 6.88" off the ground.. perhaps slightly lower in the front. The entire front end will be fiberglass sealed. I will install a drag spoiler to help diffuse the air in the rear of car. I will also spend some time cleaning up underneat the car with aluminum plating as well as the front and rear underside. It will help but it is still a very large frontal area that can not be avoided without lowering the roof line which I dont plan to do.
As for the money "wasted" dont bother me with wasting money. I smoke cigs, drink Vodka and eat out every day. This is no more of a waste than anything else I do. I enjoy it so thats all that matters
As for the its not an Evo anymore well I suppose anyone else that changes thier manuals to an auto or vica versa is a new car. Anyone that uses a chevy 12 bolt rear end instead of the stocker isnt the same car. Anyone using a dogbox. Anyone that cut anything from thier car to make it lighter, etc, etc... dont bother posting any of those comments please. Its my car, its my Evo, its my money. If you dont like it then dont try to duplicate it. If you do like it, then please do try to duplicate it... trust me its fun and kills lotsa boredom!
-Tim Russell
Old 02-16-2007   #12
EvilEvo
Now where was that kid with the Civic that wanted SOOO badly to race me lol!
-Tim Russell
Old 02-19-2007   #13
URV8SUX
URV8SUX's Avatar
I havn't gone anywere .
Old 02-16-2007   #14
Wow.
Old 02-16-2007   #15
Part of me says "Poor Evo..." The other part says "Holy shit, that's fucking cool!"
Old 02-16-2007   #16
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
My thought exsactly. I really want to see this thing at the track this summer.
11.35 @ 120mph
Old 02-16-2007   #17
EvilEvo
Im hoping to have it out and about around the 4th of July. Ill keep this updated as I go along.
-Tim Russell
Old 02-16-2007   #19
Very cool and intense project but why do that to such an expensive shell?!? I guess I dont get that part, when you could have thrown the project at a cheap DSM shell. Looking forward to seeing the final product though!
Old 02-16-2007   #20
Good luck with it! Looks like an involved project. More involved then anything I'd ever do.
