Old 02-19-2007   #1
gsxer
Which turbo would you guys prefer?
What turbo do you guys prefer?
My mods:
6-bolt motor swap w/
-arp hardware
-QPR EGR Block-off
-BS elim kit
-'90 oil filter housing
-small 16g
fmic
walboro 255
650cc injectors
polyeurethane motor mounts
ported 2g exhaust manifold
apexi n1 catback
Buschur TB elbow
2.5" downpipe, w/ dual 3" resonators, no cat
Apexi AFC-2 (getting DSMlink)
polished 1g rail with custom mounted FP gauge
10mm plug wires
RRE crankcase breather'/oil catch can
Joe P MBC
12" Fal high flow fan(pull)
10" SPAL High flow fan (push)
polished ebay strut bar
My goals 10-11 sec car. Its going to be mostly street driven and taken to the track not so often. Ive been looking and 20g's and 50 trims and ive heard good and bad about them but I just recently looked at the SCM-6152 and was kinda interested. Any imput is fine thanks.
gsxer is offline   Reply With Quote
Old 02-19-2007   #2
rst95eclipse
Re: Which turbo would you guys prefer?
I would go with the SCM61. You would never have to upgrade again. If I were you, I would definately upgrade your downpipe to 3". Now I have a question for you, why are you running 3 fans?
Old 02-19-2007   #3
How many threads do you need to start to determine which turbo to get?
Old 02-19-2007   #4
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
You dont have to make a new thread every time you have a new question about a different turbo. Just FYI.
http://www.dsmstyle.com/forums/showthread.php?t=14443
http://www.dsmstyle.com/forums/showthread.php?t=14448
http://www.dsmstyle.com/forums/showthread.php?t=14413
Old 02-19-2007   #5
You need cams first. You won't get the full performance from the SCM61 without going to a sheetmetal intake and 3" downpipe also. And if you want the full performance of the 61mm compressor wheel in that turbo, then get a SC61 with a T3 exhaust housing, T3 exhaust manifold, an external wastegate, and a good O2 housing.
Old 02-19-2007   #6
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Ecoli is right. Nobody said it was gunna be cheap. You cant just get a bigger turbo and expect it to get you into the 10s.
pics or gtfo
Old 02-19-2007   #7
gsxer
ok cool thanks ecoli for the exhaust housing would .63 A/R better or .82 A/R be better? And for the compressor cover what is the difference from "E" and "S"
And your right M.98GSX nobody did say it was going to be cheap not even me?
Old 02-19-2007   #9
With the level of questions you're asking, you shouldn't be looking at anything larger then what you already have.
Old 02-19-2007   #10
gsxer
Sorry, first posted fixed I have 2 fans.
Old 02-19-2007   #11
The S is a larger compressor cover, I have one on my SCM61, but it probably doesn't do much, the exhuast housing is the limiting factor. If you go with the SC61, then it would be more of a benefit. The .63 housing will be somewhat limiting, but the .82 housing will be laggier and flow better.
Old 02-19-2007   #12
OT but that car does have 3 fans; it's my old car & it had some overheating probs for a while & through the course of things it ended up w/ a double-pull 12" FAL and one 10" SPAL pusher. It will never overheat again now
Cams and a SMIM are going to be a must if you want to run low 11's. A gt35r or SC/SCM61 will be probably necessary to. If I still had that car it'd be getting all of the above, probably a bigger turbo tho.
Old 02-19-2007   #13
gsxer
ok thanks haha
Old 02-21-2007   #14
gsxer
Is the SCM6125 a good street turbo? or would the 20g be better for more street driving and racing?
Old 02-21-2007   #15
No that one smells like rotten apples.
But the SCM6152S is a great street dsm turbo w/lag. SC61 with a stage 5 wheel. Good for 400+hp on pump on a 2.0 with proper tuning.
Old 02-21-2007   #16
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Old 02-21-2007   #17
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
I have the 20g td06 and love it.
Old 02-21-2007   #18
Have you done any research at all?
Old 02-21-2007   #19
b00stcreep21
I hate everyone
I vote no. Google is your friend dude
