Old 02-21-2007   #1
FS Ball Bearing 50 trims, dsm bolt-on
For sale:
Quantity: 2
50-5051RE turbochargers.
Otherwise known as the SCM50 ball bearing turbochargers. Rated for 450+hp each.
These are E cover 50 trims with the upgraded heavy duty actuators. Good for 36psi of boost out of these turbo's. They also hold 18psi perfectly if requested.
They feature the td05 bolt-on flange with the cut housing to help promote against boost creep.
These turbo's have been inspected are in 100% working order. 8000 miles on them approximently.
These turbo's retail for $1299+ each, plus wastegates. I would like to dump them off as they need to go to make way for other items.
$700 each. $1300 for the pair.
Old 02-21-2007   #2
Re: FS Ball Bearing 50 trims, dsm bolt-on
Dont you mean 36psi if they are attached to a 1.5L motor
Old 02-21-2007   #3
Well then can go down to 18psi without problems.
Old 02-21-2007   #4
I'm assuming these are internally gated?
Old 02-21-2007   #5
Yes they are with the heavy duty wastegate actuators and a cut divider housing.
Old 02-26-2007   #6
Up up up..no offers?
Old 02-27-2007   #7
joem
Drives: 1991 Talon awd auto
500.00
Old 02-27-2007   #8
Originally Posted by joem View Post
500.00
A little lower than I was looking for. $700?
Old 02-27-2007   #9
swanny, put them on nabr or some other national board where the people actually have money!
Old 02-27-2007   #10
Good idea, I'll toss them up on DSM tuners.
Old 02-27-2007   #11
I'd be all over one of these if it was externally gated.
Old 02-27-2007   #12
Uhh...why?
It can be converted easily if need be.
Old 02-27-2007   #13
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
That probably wouldnt be a huge deal to accomplish.
Old 02-27-2007   #14
very easy to do both of the 61's were cut and internal to start with
Old 02-27-2007   #15
DBMajik
I'm curious how one of these runs on a stroker if you wanna donate swanny
Old 02-28-2007   #16
No longer for sale, thanks for the interest.
