Old 05-15-2007   #1
driftn1g
.020 over pistons..
Ok so i just figured out that my car has .020 oversized pistons on the rebuild.. suppositly it was rebuilt by parts from "top line" anyone ever heard of this brand??
btw what is the major difference between stock and .020
Old 05-15-2007   #2
Re: .020 over pistons..
Top Line is some cheap brand that makes a lot of OEM replacement parts. I wouldn't trust their stock replacement pistons as much as Mitsu ones.
The difference between stock(STD) and .020 is .020 inches
Old 05-15-2007   #3
driftn1g
performance wise?
Old 05-15-2007   #4
Basically nothing performance wise.
Old 05-15-2007   #5
More displacement, and thinner cylinder walls.
Old 05-15-2007   #6
By about .020" per hole I would assume.
Old 05-15-2007   #7
Pie * R^2?
Old 05-16-2007   #8
I like pie, but I believe you're looking for Pi.
Old 05-16-2007   #9
Nope, French Silk * R^2.
Old 05-16-2007   #10
I perfer:
{(Whip Cream)/(Pumpkin Pie)} * R^2
Old 05-16-2007   #11
driftn1g
soooooo if i have a 2.0 whats the displacement then
Old 05-16-2007   #12
You gained around 23cc. So you went from slightly smaller than a 2.0l to slightly bigger.
Old 05-16-2007   #13
You now have a 2.02L engine, Hondas beware!
Old 05-16-2007   #14
Isn't the displacement of the 4G63 something like 1996cc? I'd do the math if I had the specific bore and stroke measurements.
Old 05-16-2007   #15
I seem to remember it being 1998cc, but I will double-check that.
Old 05-16-2007   #16
Taken from SCC:
he 4G63 name simply indicates that this Sirius engine displaces two liters. While 4G63s have all used 85mm cylinder bores and an 88mm stroke (1997cc total displacement), the 4G63 installed in the Mighty Max pickup had 84mm bores and a 90mm stroke, resulting in 1996 cc of displacement (but the same nominal 2.0-liter description)
Old 05-16-2007   #17
driftn1g
owned.
these .020 more inches will smack on viper/vettes, i've noticed
Old 05-16-2007   #18
Originally Posted by driftn1g View Post
owned.
I seriously hope you kidding, unfortunately I doubt you are.
Old 05-16-2007   #19
About as much performance increase as going from 87 to 89 octane with no tuning changes.
Old 05-16-2007   #20
driftn1g
I'm
one day.... it will happen,
