Go Back   MitsuStyle > Hosted Support Forums > DB Performance
Old 06-07-2007   #1
No replacement for displacement?
What happens when the V8 guys find turbos?
Some of you guys may have seen this car at the shop over the winter.
We had to stop at 11psi because the mostly stock ignition couldn't keep up. You can see it in the graph when it goes flat around 5700RPMs and we stopped the run not long after. It was fine at 9psi making 770whp. The plan was to shoot for 15psi on pump gas for now and maybe max the turbos on race gas someday.
ID:	5758   Click image for larger version
ID:	5759   Click image for larger version
Old 06-07-2007   #2
Re: No replacement for displacement?
siiiiiiiiiiiiqqqqqqqqqqqqqqqq
i need some oil filters
Old 06-07-2007   #3
stikx
Mr -
Yea, after a couple years of growing up i realized more cylinders means more power easier and better powerband, just need the money now lol.
Old 06-08-2007   #4
It's not displacement, it was those NAPA oil filters that made the power.
Old 06-08-2007   #5
tim
tim's Avatar
I saw this earlier today. That is awesome.
I assume there will be a c16 tune also?
What about the TT Cobra that has been 2 years in the making?
Old 06-08-2007   #6
Yeah, I have been craving a twin turbo LS engine for a while now. Things like this make me realize that I won't get 1,000 awhp out of my car, because that is totally streetable anyway.
Old 06-08-2007   #7
Hopefully next year
Old 06-08-2007   #8
holy donkey giblets!
Old 06-08-2007   #9
4 cylinder engines are lame.
Old 06-08-2007   #10
That's fuck'n sick! Nice work guys!
Old 06-08-2007   #11
curt_gendron
curt_gendron's Avatar
Very nice!!
I'm gonna go race this sucker on Diamond Lake Blvd when I get home tonight.
hehe, maybe not.
Minnesota 3/S
Old 06-08-2007   #12
They're catching up. I've seen more and more articles about turbocharging and EFI in Hot Rod, and now they've even got a really cool cam-driven fuel pump that can provide enough fuel flow for a 1500 hp EFI engine without even putting a return line to the fuel tank. Talk about easy retrofit for the older V8 cars, bolts right in the stock location and is half the size of a stock pump.
Nice work on the Stang, I won't be lining up against many of those unless they're on cheap radials.
Old 06-08-2007   #13
I know I asked this before, but what does his car rev to?
I need a V8.
Old 06-08-2007   #14
I need a V8.
7000 or so, we brought it out a lot farther than in the graph above on lower boost runs when it didn't misfire.
Old 06-09-2007   #15
That was pump 92? Like.
Old 06-09-2007   #16
Yea, normal 92 octane pump gas. It was only 11psi. The motor was built low compression for turbo.
Old 06-09-2007   #17
Nice numbers.
Old 06-11-2007   #18
Wow, impressive. 9 sec pump gas daily driver.
Old 06-11-2007   #19
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
I think its time for a 408 and 2 turbos for the jeep!
Damn, I want money
-David C.
Old 06-11-2007   #20
Hmm, maybe I should turbo that GTO in my garage... Too bad it'd fall apart before I even turned the key.
Nice numbers!
