Old 06-13-2007   #1
Dump off of O2
Hey guys,
Im looking at this http://www.extremepsi.com/store/cust...at=1392&page=1
Because a buddy has a Tubular Manifold that doesnt have the External WG flange on it.
Currently my turbo has the Internal WG Flapper welded shut and the seperator cut as well. My first instinct is that it will not work and im stuck with an external WG off the Manifold.
Otherwise i wonder if a shop would be able to weld a external dump off of the tubular mani.
Old 06-13-2007   #2
Re: Dump off of O2
Couldn't you just cut out the wastegate flapper, then grind the wastegate hole bigger? A friend bought a SS Autocrap 02 housing, and modified if for recirc. external gated (Tial 38mm). Works awesome, and was super cheap!
Old 06-14-2007   #3
Re: Dump off of O2
Punishment Racing sells a weldup kit for $75. I'll be putting one of those in my car this weekend. I'll be having it recirc back into it's self just before the dp flange
Old 06-14-2007   #4
Re: Dump off of O2
I have a tubular manifold i'd let go for cheap. its got a tial 38mm flange off of the collector.
Old 06-14-2007   #5
Re: Dump off of O2
pm sent.
Old 06-14-2007   #6
Re: Dump off of O2
just grind out the flaper and get a o2 mouted gate. One of my pte's that I had the guy I got it from weled it sut and I just cut it out
Old 06-14-2007   #7
Re: Dump off of O2
Yeah but the problem im seeing is that the exhaust housing is the cut one, not the 02 housing, Between the WG Flapper and the exhaust wheel there is a section cut out.
Old 06-14-2007   #8
Re: Dump off of O2
that is not a problem I have made plates for 3 of my pte's that I have used to get rid of the internal cut divider's
