Old 02-12-2004   #1
-GSX-Falcon
Guest
Tournaments Won: 6
Posts: n/a
I just bought some used 450cc injectors for my upgrade from an auto setup to manual. Im missing one of those little black caps at the end of the injectors...and another is damaged. Is there anywhere i can buy a couple of those?
Also, Im going to be swapping in a manual ECU with my new injectors, so i have the correct fuel maps. Now, i have learned the FPR for automatics is set HIGHER then that of manuals. I got a whole fuel rail off a manual and thought i would switch it in so i would have the base fuel pressure that the ECU is set for. But now i hear that having higher fuel pressure can be a good thing because you can run more boost on smaller injectors. So should i keep the auto FPR and run a little rich but have a little more leway in the boost area, or run the manual FPR? Opinions?
Old 02-12-2004   #2
Call Mitsu.
Old 02-12-2004   #3
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
yeah, call mitsu. Those break easily.
7/25/09
Old 02-14-2004   #4
john
Business as usual
john's Avatar
higher fuel pressure is ok if you can lower the MAS signal via a SAFC. You will run rich during normal driving though. Mitsu has the connectors like everyone says. I have not seen them being black though. My stock 450's had an orangish color connectors. You will want to get new orings and insulators for the injectors also.
97 Viper GTS
Old 02-15-2004   #5
It probably isn't that much higher psi, the ecu should compensate for it.
Old 02-15-2004   #6
-GSX-Falcon
Guest
Tournaments Won: 6
Posts: n/a
^^^ thats what i was thinking. Long term fuel maps should lean me out.
