Old 07-15-2007   #1
driftn1g
Stumbles at high rpm then loops
ok so i finally got my car tuned for zero knock at around 16-17psi..
sometime when im in second and i smash it to around 4-5k rpm, it will studer, then will loop when i put it in neutral.. what kind of spread should i gave on the safc2 as far as percentage when im climbing rpms
i checked my IC piping, fixed my boost leak, could it be bad plugs/wires?
Old 07-15-2007   #2
DBMajik
Re: Stumbles at high rpm then loops
Considering you're on stock injectors, near stock boost, stock turbo.. I wouldn't think you need to go over even 10% correction on pump.
Old 07-15-2007   #3
driftn1g
im at like 40%.. maybe my injectors are clogged
Old 07-15-2007   #4
Are you logging? What's going on under these circumstances?
Old 07-15-2007   #5
driftn1g
well i seemed to get it better.. also ran some seafoam in it
i looked at my fuel trims Low is 129%, mid is 99% and high is 85%.. but i also dont have an adjustable FPR so i was told leave them alone??
cant remember how to adjust them, i had a write-up somewhere but lost it.. but i did get my idle to where i wanted it (750rpm)..
right now it seems like it will stop pushing at like 5k-6k, but is boosting..? rich??
Old 07-15-2007   #6
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
If what DB says is correct and you are indeed on stock injectors you should not be running so much correction. Are you on the stock fuel pump as well? If so I'd say turn the boost down a few PSI, zero out the SAFC and log it. Tune from there.
Old 07-15-2007   #7
driftn1g
im on 255lph pump
Old 07-15-2007   #8
driftn1g
btw how can u tell if u have compressor surge??
my bov flutters
is that bad?
stock 1g bov
Old 07-15-2007   #9
If you have to go positive on the hi-throttle map, then you are possibly going to run into fuel cut. You shouldn't really ever have to go much positive on a DSM, unless something else is wrong or your MAS is really hacked or you are trying to run a 2G MAS with stock 450cc injectors in a 1G.
If you are running a stock 1G MAS, you might be hitting MAS overrun.
Old 07-15-2007   #10
driftn1g
im running a 2g mas in a 1g..
should i tune with Lo-throttle map or high??
ive been tuning with high, but adjusting idle with low
what does fuel cut feel like
Old 07-15-2007   #11
Like eating the steering wheel.
Old 07-16-2007   #12
driftn1g
more discriptive???
as bad as an IC pipe blown off
Old 07-16-2007   #13
93TalonES_NWS
93TalonES_NWS's Avatar
I wear a mouth guard to protect myself from fuel cutoff
93TalonES_NWS is offline   Reply With Quote
Old 07-17-2007   #14
stikx
Mr -
LOL! Anyways fuel cut sounds similar to an IC pipe blowing off but feels like IC pipe On and oFF. Picture a little midget pulling the IC pipe off then putting it back on constantly for couple hundred rpm or however long your fuel is.
Oh yea, check your plugs, sounds like spark blow out since it's only in the upper rpms (WOT?).
Old 07-16-2007   #15
fuel cut is basically your car coughing and jerking you forward. Eating the stearing wheel isn't a horrible description. You'll know it when you get it. You should probably get some new plugs. Maybe some BR7ES...I've got a set for you for $15
Old 07-16-2007   #16
driftn1g
i got plugs.. im going to pull the old ones out and check em..
but like i said should i be tuning with lo or hi?
Old 07-16-2007   #17
driftn1g
btw what are 450cc good till
Old 07-16-2007   #18
Bunta
Bunta's Avatar
I'm know pro at this stuff but maybe any information can help you. I have my safc2 programmed to road race engineering settings. I'm just waiting on my fmic to get in then i'm going to set up an appointment with DB or Map to get it tuned.
http://roadraceengineering.com/newafcsetting.htm
A list of what you've got on your car would really help.
"What you just said was the most idiotic thing i've ever heard, everyone in this room is now stupider for hearing what you just said."
Bunta is offline   Reply With Quote
Old 07-17-2007   #19
driftn1g
stock 14b..
fmic..
i want it tuned at least 18psi
safc2
450cc
255lph
