Old 07-25-2007   #1
dragonforce
1990 Eagle Talon TSI AWD 5speed
Parting out complete car. Hit in front. Good drive train. 4 bolt rear. let me know what you need.
kiichi.
dragonforce is offline   Reply With Quote
Old 07-25-2007   #2
driftn1g
Re: 1990 Eagle Talon TSI AWD 5speed
pics of the damage up front?? may know someone interested
Old 07-25-2007   #3
HKSenilyks
Send a message via AIM to HKSenilyks
How much for the motor mounts car side as well as motor side, I'm very interested cash in hand.
Thaught
HKSenilyks is offline   Reply With Quote
Old 07-25-2007   #4
dragonforce
hit hard in left front. The whole front clip is bad. I'll try to take a picture. I should have engine mounts. I'll let you know if any good.
Old 07-25-2007   #5
Hoffer00
What kind of turbo do you have.
Old 07-25-2007   #6
How much for the entire engine wiring harness with attatched relays, resistor boxes, but not the ecu? Also the CAS, coilpack and transistor?
Old 07-25-2007   #7
4seasons69
4seasons69's Avatar
what kind of shape is the engine in? is it still good? how many miles are on it?
if the engine isn't good is the oil pan in good shape?
does it have a sunroof? if it does what kind of shape is the headliner in?
Old 07-25-2007   #8
dragonforce
I have oil pan in good shape from another engine. $25. it's already off the engine.
Old 07-25-2007   #9
4seasons69
4seasons69's Avatar
k I will probably take that oil pan. I am still kinda interested in the engine. did the accident mess up the engine or is it still good. pm me some way to get a hold of you about that oil pan.
Old 07-25-2007   #10
dragonforce
The engine should be good. it had 150k miles stock with new water pump, timing belt @30k ago. tranni was about 100k with no grind. I'll inspect it close before selling it. I can pull wiring harness. I have cas, coil pack, transister.
Old 07-27-2007   #11
Do you have an idea of what you want to get for that harness and engine electronics?
Old 08-01-2007   #12
HKSenilyks
Do you have those motor mounts if so, how much
Thaught
Old 08-05-2007   #13
4seasons69
4seasons69's Avatar
I think I am gona need a new engine soon. so I would like to know how much would you sell the engine and tranni for. what's the compression like?
Old 07-27-2007   #14
turboDSM
turboDSM's Avatar
Drives: tastefully modded BMW : )
14b?
turboDSM is offline   Reply With Quote
