Old 07-27-2007   #1
tnm27
I'm the short one.
tnm27's Avatar
Timing Belt SNAPED!
okay, I just got a call from my brother who's on 94 Westbound. He said he was driving and all of a sudden he heard something from the engine....pulled over and checked it out...he found the timing belt had snaped....I'm at work currently and haven't gotten much info from him...i'll be busy as heck this weekend, but i will run some tests to see what my compression, etc...anyways my question(s) is.....what causes the timing belt to snap like that? Out of a month I've only drive the about 5 times. I let my brother drive it to work and school cause he needs a car...Will abuse cause it to snap? I do know my brothers got a heavy foot, and i've constantly nagged at him about laying off the pedals and not racing. The times I drove it, the car sounded fine, all I know is that it needed an oil change...but thats got nothing to do with it.....I hope no bent valves or damaged internals...PLZZ....hehe...
This might be the end of her(my car)...
o yeah...its a 91 GSX, No mods what so ever upset N1 exhaust...did a stock rebuild about 10,000 miles ago.
2008 Mazda 3 (Daily Driver/family car)
1991 Mitsubishi Eclipse GSX...(on jack stands....still....) :)
tnm27 is offline   Reply With Quote
Old 07-27-2007   #2
Re: Timing Belt SNAPED!
Over tensioning can shorten the life of it.
Old 07-27-2007   #3
check the backside of the belt when you see it next. If it's got wear marks on it, look at what's rubbing. Tensioner facing the wrong way? (turn the other way on a 2g) longer bolt in the oil pan cutting into the belt?
-A. Swift
Old 07-27-2007   #4
v8klla
v8klla's Avatar
You will more than likely have bent valves...Sorry to hear about your misfortune!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 07-27-2007   #5
SBR_240sx
Send a message via AIM to SBR_240sx
Goodbye valves and maybe pistons too depending on when he shut the car off. Post pics of the DAMAGE !
SBR_240sx is offline   Reply With Quote
Old 07-27-2007   #6
Yeah, the valves are toast and possibly more. You could have seized a balance shaft or something ate throught the belt, like Chris said.
Old 07-27-2007   #7
i know who was responsible...
or maybe the belt SNAPPED
Old 07-28-2007   #8
santa
Boost Spike
santa's Avatar
If you put the wrong bolt in to hold the oil pan, right below the crank pully, it can rub through your timing belt. I've seen that happen. Good luck with it!
