Old 07-28-2007   #1
Berda
Berda's Avatar
Send a message via AIM to Berda
Fuel cut with a GM maf
I have 450s, 190 fuel pump, and aftermarket fpr. i have the maf set to 450s, any suggestions to trick it into not fuel cutting?
thanks,
Berda
'91 TSi AWD Stock - 161.7 AWHP! Sold :(
'99 Honda Accord EX Coupe V-6.
Berda is offline   Reply With Quote
Old 07-28-2007   #2
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: Fuel cut with a GM maf
Bump the fuel pressure and retune for larger injectors?
Do you have it in draw through or blow through setup? If it's draw through you could have boost leaks causing fuel cut.
Old 07-28-2007   #3
Bigger injectors or chip the ECU.
Old 07-29-2007   #4
Berda
Berda's Avatar
I didn't know there was a way you could change it from draw thru to blow thru. What switch is it on the board?
Old 07-29-2007   #5
Draw-thru = maf infront of turbo (stock location)
Blow-thru = maf behind turbo
You shouldn't need to change anyting on the translator to swich from draw-thru to blow-thru. It's just the difference in placement of the air flow sensor in the intake tract.
