Old 09-19-2007   #1
justinhill
BetHiLow Streak Un-Censored Champion! League Bowling Champion! Snowboard Champion!
Drives: 98 gst eclipse
Send a message via AIM to justinhill
Fluid for clutch?
im stuck at work right now and i called checkers and he said to me i need to find out if my clutch takes oil or tranny fluid i have the act2100 please help asap i want to get home.
justinhill is offline   Reply With Quote
Old 09-19-2007   #2
Re: Fluid for clutch?
You need a GL-4 fluid in your transmission; you need a DOT3/4 for your clutch's hydraulic system.
Old 09-19-2007   #3
justinhill
so my clutch is stuck to the ground and will only come up if i bring it up by hand and the fluid in the little round container on driver side is gone so i would need the dot 3/4?
Old 09-19-2007   #4
Yes. And you probably need to figure out where the old stuff went and why it's gone. If you have a hole in one of your lines, and it all leaked out, simply filling it will not fix it because it'll squirt right back out.
Old 09-19-2007   #5
justinhill
how many quarts do i need?
Old 09-19-2007   #6
Less than a quart, a pint bottle should be plenty. Filling it up isn't going to do anything b/c you probably either have a shot clutch master or slave cylinder, and with an empty bottle there will be air in your lines.
Old 09-19-2007   #7
justinhill
the hole clutch and trany is brand new but oh crap nvm i hope i can make it home
Old 09-19-2007   #8
Doesn't matter. Follow what Kracka said.
Old 09-19-2007   #9
What does a new clutch and transmission have to do with an old worn out clutch hydraulic system? These are the parts that connect your clutch pedal to the actual clutch and they are fairly common failure points on a DSM.
Old 09-19-2007   #10
Brake fluid, doesn't really matter the grade. Far less than a pint, even with bleeding.
