Old 10-12-2007   #1
Once again, no start.
I went out to my car to go to work this morning, got in, turned the key to the ON position, let it sit for a second, and everything was fine. As soon as I turned it to START and the starter engaged, everything went dead. This same thing happened once before a few weeks ago, but everything came back on right away. Anyone know what might have happened? Is there a main ignition relay or fuse I should check? I looked around a little bit, but it was really dark and I couldn't really see anything.
Old 10-12-2007   #2
Re: Once again, no start.
I said this in the other thread, but just for good measure: This happened to my 1G several times. I ended up having to clean up the connections on the battery terminal REALLY good. Both the battery terminals themselves, and the wiring that hooked onto them. Mine happened a few times while driving or while I was out and about though, and I had to just wiggle the connection back and forth on the terminal a bit for everything to start working again.
Old 10-12-2007   #3
I also had the same problem Scheides had, it was intermitent. Cleaned the terminals well and that solved it. The other problem I had was the caps in the ECU but you did that I think.
Old 10-12-2007   #4
Got it figured out. The power wire for my amp has a weird terminal and there was just a bad connection there.
Old 10-12-2007   #5
Awesome!
Old 10-12-2007   #6
Ya ive had the smae problem and solution, but aint it the worst feeling heading to work or school and you get that click, click, nothing. Then like 5 min to figure out either how to fix it or how to get where our going. DSM=stress
Old 10-12-2007   #7
your car is trying to tell you something kevin. do what craig does and call it names so it does not brake.
Old 10-12-2007   #8
Believe me. There were some choice words said. It just pissed me off cuz the battery was the first thing I checked.
Old 10-12-2007   #9
ya because there is talk of a new bov.so the car is pissed
Old 10-12-2007   #10
That and I fixed the boost leak at the biss oring yesterday
Old 10-12-2007   #11
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
This is why I have 2 DSMs, when one breaks, there is a back up to drive... or for parts
