Old 10-14-2007   #1
Vibration/Noise on Decel
1g awd 5spd
At highway speeds when decelerating, I hear/feel a noise and vibration, kinda like a thumping. My guess is the carrier bearings on the driveshaft... Anyone have any ideas?
Old 10-15-2007   #2
Re: Vibration/Noise on Decel
I would assume carrier bearings on the drive shaft like you said. When I launch my car I can hear the driveshaft thumping, and on decelleration I can hear it making a little noise sometimes. A good way to check is to grab the driveshaft and see how far it moves in the bearings. On my car, it moves quite a bit inside the bearing case.
Old 10-16-2007   #3
Well, are you refering too the rubber surround that goes around the driveshaft? 'Cause I can grab the shaft and with little effort move the driveshaft all over the place at both bearings.
Old 10-16-2007   #4
that would be both carrier bearings. They are not to fun to change. mitsu only part also
Old 10-17-2007   #5
Isn't there a cheapo fix for this that works sometimes? Like fill in the bearings with some sort of thick lube or rubber gunk?
Old 10-17-2007   #6
Ahh yes, here it is. Just black silicone caulk:
http://www.plymouthlaser.com/shaft.htm
DO IT!
Old 10-18-2007   #7
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
Send a message via AIM to gofastman
check the universal joins as well.
have someone look under the car while you feather the clutch in and out with the parking brake on, this will load/unload the drive shaft so you can check for excesive play
-David C.
Originally Posted by bouncer07
If you know Mary Clifford, Ph,.D. Associate Professor of Criminal Justice in St. Cloud State University. Then your well aware of who she is.
gofastman is offline   Reply With Quote
