Old 02-20-2008   #1
intake dilemma
Right now I am running an injen intake that hooks up right to the stock 2g mas and then has a 2.5 inch outlet to my 50 trim. I really hate the fact that my the outlet on my intake is smaller than the intake on my turbo.
I was thinking about going with a maft and then running a filter right on my turbo or using another 3'' intake pipe I've got. After reading a little I got the vibe that not too many people think the maft is really worth the money. I'm running dsmlink so from what I understand, I don't necessarily need a maft for more advanced tuning capabilities.
The only other option I could think of was to have an intake custom made. This seems a little pricey as well considering I'd need a recirc pipe welded on. I'd also need a coupler that goes for a 3'' circle to the oval shape of the 2g mas.
That's about all I can think of. I'd like to know what other people are doing and any advice you guys might have. Thanks
-brian
Old 02-20-2008   #2
Re: intake dilemma
What I did to get the injen intake to fit my 20g is cut it up before the bend and put a 45 degree coupler the nessicary size on there so it was more open. Here is a photo.
Old 02-20-2008   #3
Re: intake dilemma
Is the injen intake really 3'' all the way down until the bottom bend? My car is in storage otherwise I'd just go look. This sounds like a very simple alternative.
I'm still open to other's advice.
Old 02-20-2008   #4
Re: intake dilemma
The 1G I drive has a 4" intake on the turbo and the 2G MAS on it is essentially a 4" also, just oval shaped. A normal round coupler works fine. I have a 3" intake pipe, so I am in the same boat, the MAS side on mine works fine, but then into the bigger turbo is kinda stupid.
Old 02-20-2008   #5
Re: intake dilemma
So you just used a circle coupler and clamped it tight around the mas?
Old 02-20-2008   #6
DSM_421
Re: intake dilemma
This is a setup that would probably work nicely for you. That is a pte scm50, and those are just round couplers on a 2g mas.
http://www.hbci.com/~jbeebe/Talon/DSC02446.JPG
Old 02-20-2008   #7
Re: intake dilemma
Great find thanks! I think i might try that with the 3'' intake I have. Unfortunately it's shorter than the fp ones so I might have to try and angle it downwards because it doesn't quite get up high enough. Not sure if the mas will stretch that far down though.
btw, where have you guys remounted your ecu if you have long route piping like myself? I know some people just wire it inside their car, but I'm not that hardcore nor do I have that much time on my hands. Right now it's just kinda shoved down and I really hate it.
Old 02-20-2008   #8
Re: intake dilemma
Relocate the ECU? I think you must mean something else unless your intercooler piping goes inside the car. Do you mean the fuse box?
Old 02-20-2008   #9
Re: intake dilemma
haha oops. It'd be a little tricky and pointless to relocate your ecu huh haha.
Here's where my fusebox is now. It couldn't stay in the stock position because my ic pipe runs right where it should go. I'd like to mount it right where my air filter is in this pic but idk if It will reach.
Old 02-20-2008   #10
Re: intake dilemma
The ECU is behind your radio. You don't normally ever have to move the fusebox, except for looks.
Old 02-20-2008   #11
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: intake dilemma
On my 1g I've got a MAFT in Blow through which allowed me to run a 3 inch pipe to the old side mount location. Not worth $200 on it's own, but really cleaned up that area of the engine bay. You essentially see nothing on the transmission side of the motor. It eliminates the whole recirculation tube as well.
Old 02-20-2008   #12
Re: intake dilemma
Sounds like the Dejon CIP-2gS intake for $160 would work perfectly for you.
Old 02-21-2008   #13
Re: intake dilemma
Is that a 3'' outlet? I've seen those but haven't found much info on em.
Old 02-21-2008   #14
Re: intake dilemma
If you do decide to go with a gm maf in blow thru, I would still be leary of putting the filter right on the turbo. Think about it, the air it's taking in has just come through your radiator, and that shit is hot! At least with it in the stock location, it's getting somewhat cooler air.
Old 02-21-2008   #15
Re: intake dilemma
I said that more just to clarify things. I mean so I could have the option of putting it on the turbo. I know the air would be pretty hot. Thanks though
Old 02-21-2008   #16
Re: intake dilemma
The inlet to the intake is the same oval shape/size as a 2G MAS and the outlet is 3" to match your turbo.
http://dsm.dejonpowerhouse.com/
Old 02-21-2008   #17
Re: intake dilemma
here is a extra one I have 3in all the way and 3in k&n was used on a gm maft set up till we put on a gt35 and made a 4in intake for it
Old 02-21-2008   #18
Re: intake dilemma
^idk if you are offering to sell that, but I need the recirc tube so that wouldn't work unfortunately.
And Kracka that dejon looks sweet but it's kinda pricey. We'll see what my injen intake goes for.
Old 02-21-2008   #19
Re: intake dilemma
Just get the 4" FP intake, that way if you ever get a turbo with a 4" intake you won't be in this situation again. And it's only $79 base price, +$25 for BOV return, +$29 for 4"-3" reducer coupler for your current turbo.
EDIT: Kracka beat me to it...
Old 02-21-2008   #20
Re: intake dilemma
http://store.forcedperformance.net/m...ode=DSM-Intake
FP cast aluminum 4" intake, $133 with couplers and BOV return tube.
