Old 02-27-2008   #1
eclipse_spyder
The most ricest dsm
head work shop
Is there a shop that just does porting on the valve ports without cleaning the head and installing internal parts? I think my head might need to be decked also. I'm going to run 1mm oversized valves. I just need the valve ports to be 1mm bigger.
eclipse_spyder is offline   Reply With Quote
Old 02-27-2008   #2
Re: head work shop
Probably not. The head needs to be throughly cleaned if you port it or deck it. And the 1mm over valves will need a valve job and need to be installed. You can put in 1mm over valves without doing any special porting. If you have stock pistons though, make sure the bigger valve aren't going to contact the pistons. Aftermarket pistons have larger/deeper valve reliefs.
Old 02-27-2008   #3
Re: head work shop
Originally Posted by eclipse_spyder View Post
Is there a shop that just does porting on the valve ports without cleaning the head and installing internal parts? I think my head might need to be decked also. I'm going to run 1mm oversized valves. I just need the valve seats cut to match my 1mm over vales as well as cutting the valves.
Fixed it for you.
Old 02-27-2008   #4
Re: head work shop
You might want to install new guides also, just a thought.
Old 02-27-2008   #5
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: head work shop
I have new bronze guides. LEt me know if you are interested.
Amsoil Dealer
Old 02-27-2008   #6
eclipse_spyder
The most ricest dsm
Re: head work shop
The head is kinda clean. I haven't taken out the valves and springs but once I do, the whole head will be very clean after I clean it. I will not be using any stock internals as everything will be upgraded. I'm planning on using the brand ferrea for valves.
I guess what I'm looking for now is hot tanked and cleaned, decked, 1mm oversize valve seats, and installed valve springs and valves? Is there any shop that just does those instead of doing a full head install and porting on the intake and exhaust ports? I will be providing the valves and springs.
Old 02-27-2008   #7
Re: head work shop
That is what a machine shop normally does. Headwerks is pretty highly recommended, but a little spendy.
