Old 04-12-2008   #1
dustinw
dustinw's Avatar
Drives: 96 Talon TSi AWD
e-85 conversion
i know theres a few e-85'ers on these boards. and im curious what all is needed to get my 2g dsm running on e85, cause to be frank. i paid 3.80 a gallon for gas last week and its getting old fast.
dustinw is offline   Reply With Quote
Old 04-12-2008   #2
DSM_421
Re: e-85 conversion
E85 is less expensive... but you won't get the same gas mileage so it all evens out pretty much.
Old 04-12-2008   #3
Re: e-85 conversion
You end up spending about the same wieh the gas prices are higher but you save some when they are lower. Plus you can get more power off of E85. Get bigger injectors, bigger fuel pump, and something to tune with like a wideband and a safc and you will be set. Some replace the fuel rail with a anodized one but it has been done without with no problems. Good luck.
Old 04-12-2008   #4
Re: e-85 conversion
google dsm e85 conversion. Basically upgrade your fuel system and get an engine management
Old 04-12-2008   #5
DSM_421
Re: e-85 conversion
Don't you have to do shit to your lines?
I guess I don't really know because I'm pump 92 fo lyfe, but I thought the alky eats through rubber hoses?
Old 04-12-2008   #6
Re: e-85 conversion
Don't worry about factory lines, it's a non-issue, at least for several years. And if you do have to replace your one or two rubber lines, they're about $30 new from Mitsu.
Old 04-12-2008   #7
Re: e-85 conversion
If one more E85 thread pops up on here i may just have to kill myself.
Old 04-12-2008   #8
Re: e-85 conversion
Apparently people do not know how to use the fucking Search function.
Old 04-12-2008   #9
Re: e-85 conversion
I agree. READ a few
http://www.mitsustyle.com/forums/sho...&highlight=e85
Plenty of reading to do here so have fun.
Old 04-13-2008   #10
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
Re: e-85 conversion
you cant control the huge injectors you'll need with a safc you'll need to run link or ams
Old 04-13-2008   #11
DSM_421
Re: e-85 conversion
He is fairly new he might not have known about the search botton.
Old 04-13-2008   #12
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
Re: e-85 conversion
There isn't really anything to convert. Technically you're not sopposed to be using aluminum fuel rails, factory seals, etc. I have ran it on the stock fuel system w/dsmlink. Just for DD. Just make sure you have an ample fuel supply.
Old 04-13-2008   #13
Re: e-85 conversion
I think I need to make an E-85 conversion sticky or how-to!
Old 04-13-2008   #14
Re: e-85 conversion
That would be easy, link to the search button.
