Old 04-22-2008   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Converting a NT throttle body?
what do you all need to do to a nt tb to run it on a tuebo car? Any part numbers for seals?
Amsoil Dealer
Old 04-22-2008   #2
Re: Converting a NT throttle body?
just bolt it on they are the same as a turbo one but with the lip on it. Or if you want to find a evo III t.b. they are bigger than a 1g.
Old 04-22-2008   #3
Keep in mind you will have to modify your intercooler piping once its on there! No elbow coming off of the TB.
Old 04-22-2008   #4
Does the evo III have the lip or not?
Old 04-22-2008   #5
that they do. they also use 2g sensors
Old 04-22-2008   #6
Oh, nice. Is there a good spot to find these?
Old 04-22-2008   #7
just look on ebay they are on there some time but sell for alot
Old 04-22-2008   #8
95talonracer
Finally Tuned...
Drives: Spyder GSX
oh ok easy enough I thought that I herd that you had to do different seals for some reason, never mind. does anyone have an idea of the degree of the angle from the tb to next to the radiator where a short route intercooler goes on a 2g? it doesn't look like my 45 degree coupler I ordered will work.
Amsoil Dealer
Old 04-23-2008   #9
I have short route piping and it's an exact 90 degree angle if you have the upper pipe running straight front to back, although my 90 is in my piping.
Old 04-22-2008   #10
brando
Drives: gutlass
what are you looking to gain from using a nt tb? is there some performance increase?
Old 04-23-2008   #11
My motive for doing it was just eliminating one more flange that could potentially be a boost leak. I prefer the coupler connection.
Like Schiedes said, slight modifications will have to be done to your UICP.
Old 04-23-2008   #12
I have a straight streached 2.5 cuppler over my evo III t.b. and right into a 90 2.5 pipe
