Old 06-02-2008   #1
thesoccadude
My car stutters...
Call me a newbie... I just installed my td06 20g, 2g mani with hks wastegate and some 660cc injectors along with some bc 272 cams. i start it up and of course idle is lumpy. the problem happens when i start driving it. it doesn't build boost at all, instead it tries and drops, my entire car jerks around. I've been told this was a boost look but i highly doubt it is.. i checked everything over... could it be i'm just running super rich?
thesoccadude is offline   Reply With Quote
Old 06-02-2008   #2
DSM_421
Re: My car stutters...
You have some sort of way to tune the car? Or a chip atleast for the injectors?
Old 06-02-2008   #3
thesoccadude
nothing... think that's the reason?
Old 06-02-2008   #4
You're running 660's and a 20g without any sort of fuel control?
Old 06-02-2008   #5
brando
Drives: gutlass
well what is your fuel pressure set at? check all vacuum and boost lines. check your timing you may need to advance it a lil bit. check your plugs and if they are super black then you are running too rich and if they are white then your in need of more fuel. = and you might need to go dsm link if nothing else works.
welcome to the land of D.S.M.
Old 06-02-2008   #6
Yea sorry man, if I woulda known you didn't have anything to tune your car with I woulda told you that right away. If you did a boost leak test and it checked out good then you should just need something to tune with and you'll be set.
Old 06-02-2008   #7
thesoccadude
anyone make chips to compensate?
Old 06-03-2008   #8
Hope you have an eprom ecu.
http://www.dsmchips.com/
Old 06-03-2008   #9
DSM_421
Easy way to tell if your ecu is eprom or not is to see if it has an E on the outside of the casing.
However, that doesn't always mean it is eprom, in the 1gs sometimes it will have a eprom case with a non eprom ecu inside. If you can pull it out and open it, you will notice a chip on the bottom right hand corner of the board, that means you have an eprom.
Old 06-03-2008   #10
thesoccadude
it's a galant vr4. no worries there. anyone local?
Old 06-03-2008   #11
Just because it's a VR4 doesn't mean the E-Prom ECU is still in it. Unless you're the original owner
Old 06-03-2008   #12
DSM_421
What do you mean anyone local? Lots of nukkaz here are local.
Old 06-03-2008   #13
thesoccadude
local person that does chips.
Old 06-03-2008   #14
DSM_421
Maybe DB? But your best bet is what super bleeder recommended.
Old 06-03-2008   #15
Yea shane @ DB can do chips. But you'll need to have him or someone socket your eprom so that you can actually swap chips.
Old 06-03-2008   #16
mdost03
Sonic Champion!
Drives: VA STI
If you need just a basic fuel controller and don't have the eprom ecu, look into the SAFC2. Will be able to get you by.
Old 06-03-2008   #17
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
just use an afc or dsm link and have it tuned...
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 06-03-2008   #18
For the time being, the cheapest way to go is to just get your ECU socketed and chipped (providing it's an Eprom). Shane at DB burned a chip for me and it worked great till I was able to get DSMlink and a tune from him.
Old 06-03-2008   #19
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
Cool Re: My car stutters...
Call me a newbie...
Noob, you have twice as many posts as me and you don't know you need something to control bigger injectors? And I thought I was a noobhahahaha JK
Old 06-04-2008   #20
pwned
