Old 07-11-2008   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
FS Tons of mitsu parts
Here is all that I have that I am trying to get rid of. All is Best Offer so send me a PM of what you need and an offer on it.
timing belt pullys (500 miles)
intrepid coil with pig tail
manual tranny clutch fork boot
tinted narrow band air fuel gauge
Coil on plug COP setup
4 AN 180 degree hose end
6 AN 45 degree end
stainless braided turbo oil feed line with fittings from head 1/8 NPT
fuel line from filter to rail (stock)
starter
3 ss AN line with one end 20" long
All valve cover bolts
plug wire covers (Mitsubishi and stripe)
turbo coolant hard lines
b&m fuel pressure gauge (comes with adapter to mount on fuel filter)
harmonic balancer
stock oil fill cap
2" 90 degree pipe Stainless
balance shaft tensioner pulley
deltagate mark 2 wastegate (needs seal)
91.5 up center differential stock
timing belt (100 miles)
1g light grey leather seats front back and matching door panels
1g 90 to 91 center differential stock
1g 90 to 91 center differential 4 spyder
1g transistor box 91 up
1g front AUTO AWD axles
1g stock wheels
1g throttle position sensors TPS
1g radiator hoses
1g front seal cover
1ga pass headlight seal
1g thermostat housing
1g dip stick and tube
1g fuel rail with regulator
1g upper coolant pipe
1g injector resistor box
1g 91 and up shifter assembly
1ga driver side running light
1g bov recirculation tube
1g front rotors brand new
1g balance shaft sprocket, spacer, and pulley
1g lower timing sprocket
1g front and rear upper metal timing belt covers
1g passenger motor mount
1g driver side running light
1g gauge cluster 112K
1ga brand new headlight bulbs
1g passenger dark grey visor
1g driver power mirror black
1ga silver pop up headlight assembly
1g talon behind driver door molding silver
1ga passenger headlight motor
1g rear motor mount
1g gauge cluster trim
1ga passenger headlight trim
1ga driver upper headlight trim
1g cams
1g intake manifold
91 automatic transfer case
1g coil pack
1g driver passenger floor mats dark grey
1g SMIC intercooler
1g grey door driver panels
1g passenger door panel
1g under steering wheel grey foam trim (by knees)
1g talon passenger tail light
1g driver pasenger B pillar plastics
1g carpet chenter consol kick panels
1g driver under door side molding
1g driver passenger A pillers
2g fuel rail
2g driver motor mount
2g throttle body
2g FWD rear wheel bearings
2g 97 Gst ecu
2g fuel pressure regulator FPR and b&m adjustable regulator
2g front seal cover
2g FWD front brake pads (500 miles)
2gb foglights
2g gauge cluster trim (stock)
2g gauge cluster trim (dual gauges)
2g blinker assembly
2g stock fuel pumps
2g stock intinity amp
2g FWD fuel sending unit
2g head
2g AWD front axle passenger
2g throttle body
95 96 manual transfer cases
2g shifter assembly
2g non LSD rear end complete with cradle wheel bearings and all
2g non LSD rear axles
2g built FWD TRE tranny
2g 95 96 awd manual tranny
2g radiator
2g intake manifold (one with MAP sensor)
2g steering wheel dark grey
2g talon passenger tail light
2g passenger white door
2g rear speaker plastic black
2gb front bumper
2g black dash
2g passenger floor mat (eclipse)
2g FWD driver axle
5ft 2g mas extension wire
2g grey front cloth seats
2g mas air flow sensor
2g driver front splash guard
2g SMIC shroud
2g driver inner splash guard
Amsoil Dealer
Old 07-11-2008   #2
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: FS Tons of mitsu parts
I am interested in the Fuel Pressure gauge & adapter.
How much? I'm up in Ramsey and could meet up with you.
Old 07-11-2008   #3
PMd about axles and fuel line.
Old 07-11-2008   #4
green hornet
how much do you want for the 2.5" TB elbo and the air fuel gauge
FASTER AND FASTER! TILL THE FEAR OF DEATH IS OVER COME BY THE THRILL OF SPEED!!!
Old 07-11-2008   #5
Project2G
Semper Fidelis
Project2G's Avatar
Drives: 1997 Eclipse GST
Is the 2G radiator oem or aftermarket?
Old 07-11-2008   #6
95talonracer
Finally Tuned...
Drives: Spyder GSX
Amsoil Dealer
Old 07-11-2008   #7
joesushi
Smells Like Fish
joesushi's Avatar
Drives: 96GSX
I would like to buy the front bumper cover for sure.
i might be interested in the ecu, transfer case, stock fuel pumps, 2g head and 2g intake and some other parts.
When could i come by to take a look?
Old 07-11-2008   #8
95talonracer
Finally Tuned...
Drives: Spyder GSX
The wheels (2) are ok but need cleaning.
You can just give me a call and come out this weekend if you want.
Amsoil Dealer
Old 07-11-2008   #9
2bar1g
Member
Drives: .
Do you have a better pic of the 1g wheels? What kind of condition are they in? How many?
2bar1g is offline   Reply With Quote
Old 07-11-2008   #10
jhaan_dude
jhaan_dude's Avatar
Drives: a car
how much for both starters, 1g dipstick, and the custom short mitsubishi coolant reservoir with sensor (good for short rout intercooler piping).....thanks!!!
Old 07-12-2008   #11
T is for TURBO
Drives: A car
Interested in 1g stock gst rims (2) of them for $20 with no tires please...oh yea they aren't bent or have the outer bead lip bent inward..right?? PM where to meet up. thank you
T is for TURBO is offline   Reply With Quote
Old 07-13-2008   #12
95talonracer
Finally Tuned...
Drives: Spyder GSX
They are good. anytime sunday (today) works.
Amsoil Dealer
Old 07-13-2008   #13
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Do you happen to have the rest of the panels for the black dash?
Like Air bag, glove box, all the other small black panels that go underneath?
Originally Posted by shoutbox
Old 07-18-2008   #14
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
So you dont want to sell this stuff? Its been 4 days since I've asked about it...
Old 07-18-2008   #15
95talonracer
Finally Tuned...
Drives: Spyder GSX
I dont. I only have the black dash. It was dyed black but looks parfect infact I couldnt tell until i flipped it over. I want it out of here so ill sell for very cheap.
Amsoil Dealer
Old 07-13-2008   #16
kerry pm with what you want for this stuff
1ga driver front running light
2g AWD front axles
95-95 t.c.
Old 07-15-2008   #17
T is for TURBO
Drives: A car
Still interested in 1g stock rims???
Old 07-17-2008   #18
T is for TURBO
Drives: A car
Friday morning I can stop by and buy the 1g rims for 30.
Old 07-18-2008   #19
Just got back from picking up some parts, he has a ton of stuff.
Shane/Ecoli needs a 1g radiator if you have one.
Old 07-18-2008   #20
95talonracer
Finally Tuned...
Drives: Spyder GSX
All i have is a 2g radiator. The 1g one I had was really ugly so it went to the dump!
Amsoil Dealer
