Old 08-04-2008   #1
iceminion
iceminion's Avatar
bad idea or terrible idea?
in my never-ending quest to vent crank case gasses, this is what I have done: Drilled a hole in the side of the block, and attached a -10 AN line to the side of the block, this will go to a huge catch-can. Results after the first drive.
Name:	iphone import 002.jpg
building a 3000GT AWD Turbo.
Old 08-04-2008   #2
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: bad idea or terrible idea?
I'm really leaning twards terrible idea.. only because I would never drill into the block, I would think that it would make it weaker and give way under pressure
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 08-04-2008   #3
badinblack
badinblack's Avatar
Drives: 96 talon, 2.4L & 3582r
....It...might.work....??..
badinblack is offline   Reply With Quote
Old 08-04-2008   #4
Good god kid... Where the hell do you come up with all these crazy ass ideas?? Massive drug influence?
Old 08-05-2008   #5
iceminion
iceminion's Avatar
na, probably just the massive amount of undiagnosed PTSD that i got back in 'raq
Old 08-04-2008   #6
If you post it I assume straight away its a bad idea. How about fixing the rings that are shot in your motor to eliminate some crank case pressure, or just buy a real vacuum pump?
Old 08-04-2008   #7
The real fix!
Old 08-05-2008   #8
iceminion
iceminion's Avatar
well, this engine was just rebuilt .20 over all machine work done by john gosh, rings staggered properly and last time we did a compression test, it was 200 across the board, your call
Old 08-04-2008   #9
Lawl
Old 08-05-2008   #10
Well it looks like its already leaking. and wouldnt this spit a lot of oil into the catchcan. Man how pissed are you going to be if that messes up your block
Old 08-05-2008   #11
iceminion
iceminion's Avatar
the hole i drilled was in the balance shaft chamber, it was very thin, only about 3mm thick. the drips are weatherstripping adheasive.
On my buddy's turbo ford, there is a hole drilled in the aux shaft chamber similiar to where i drilled it on the 4g63. The turbo ford motor guy never has had a valve cover leak, and wonders why 4g63's dont have a crank case vent, only the head pressure relief vents.
should be installing the engine tonight!
Old 08-05-2008   #12
311evo
311evo's Avatar
judging by the idea and picture, terrible
Old 08-05-2008   #13
What symptoms are you seeing that are making you do all of this?
Our crankcase vents out the valve cover ports. If you have quite a bit of excess pressure, why not just add a second fitting to the valve cover like has been done time and time again? Or like has been mentioned, just hook up an actual vacuum pump.
Old 08-05-2008   #14
I'm convinced that iceminion and Tom chat late at night and come up with these things and give eachother advice in general.
Old 08-05-2008   #15
DAMN YOU!! While reading this i was telling myself "do not draw attention to yourself and perhaps they group you with him." Then Matt had to go and talk shit. Like always...
Old 08-05-2008   #16
Wow.. im not sure what to say. You must be bored and like to waste money.
Old 08-05-2008   #17
Wow, I am voting terrible idea.
Where is the vote button?
Old 08-05-2008   #18
If you have good compression, why would you waste your time with this? There's a good chance your block will just crack around it, and in the end it really accomplishes nothing.
Good work though, come find me at the cookout and show me this mod, I want to pat you on the back for most-amazing-silly-overkill-pointless-but-well-attempted-and-humorously-executed-mod ever
Are those lines from Slowboy Racing? :P
Old 08-05-2008   #19
iceminion
iceminion's Avatar
the engine was rebuilt, and then was used in my brother's laser which put down an estimated 350 whp (not bragging, just it was pushing some serious HP)
he was constantly plagued by oil leaking over everything, we tried every trick in the book to stop the oil seeping out of the top end, to no avail.
My brother decided to quit while he was ahead, parted his car, and bought a 2g. I grabbed his motor.
So, all I am doing is applying a feature common on other turbocharded cars.
I drilled the hold in a non-structeral location on the side of the block, I didnt drill through any major "webbing" in the casting.
Old 08-05-2008   #20
350 is not Serious HP, esp. today.
and the oil leaking could likely be fixed by sealing the individual leaks, or building the motor properly. Whenever i had a problem with the oil leaking out the vc, its always been either the valve cover is cracked, or the gasket is shot. Get a new rubber gasket and call it a day.
