Old 09-08-2008   #1
Mini wire-tuck on the evo
After drooling over kevin's 1G a little on friday night I decided to see what I could do to clean up the stock wire routing. I ran the wires that go across the intake manifold every which way and ended up settling on leaving about half running across the top front and all of the manifold-mounted sensors and TB wires run underneath and tucked.
The pile of little mounting clips and crap I removed:
Overall I'm kinda happy, but for this to really work I'd still need to extend:
-all 4 injector leads
-front o2 lead
-power steering lead
-ignition leads to left coil
Anyone know where I could get extension plugs/mini-harnesses to make this happen w/o cutting up my harness?
Here's a more stock-ish shot from about 2 years ago just for reference:
Old 09-08-2008   #2
311evo
311evo's Avatar
Re: Mini wire-tuck on the evo
looks alot cleaner
Old 09-08-2008   #3
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Just extend the wires. You'll have to either way if you want to do a semi-clean wire tuck. Make sure you do a good, clean job however you extend them. There's a lot of moving things and vibration.
When I did the Laser, I had to extend only a few wires but they were for the rf pop up motor.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 09-08-2008   #4
Ya, see I suck at soldering so that's the thing preventing me from taking a snips to them immediately
Some day I'm sure I'll break down and get r done, extending this one harness alone would clean up the engine bay considerably.
Old 09-08-2008   #5
Looks a tad better, mitsu doesnt like to make engine bays too pretty. Its hard to work around all the clutter.
Your air filter needs an oiling or replacement, its kinda rusty! haha
Old 09-08-2008   #6
Ya don't mind the rusty filter, it'll get replaced someday :P
Old 09-08-2008   #7
123abc
123abc's Avatar
Drives: Loud cars
Get that battery in the back too, that will clean it up considerably. When I extended some of my harness, I just used extending crimpers. Just wrap them real good with electrical tape and I don't think you'll have a problem.
Old 09-08-2008   #8
extending crimpers? Please explain!
Mini battery is good enough for me, no need for a move to the trunk.
Old 09-08-2008   #9
mdost03
Sonic Champion!
Drives: VA STI
I would recommend soldering. Would look a lot cleaner and be the best connection possible with no chance of coming apart under vibrations or anything.
Old 09-08-2008   #10
123abc
123abc's Avatar
Drives: Loud cars
Like these:
Old 09-08-2008   #11
Butt connectors.
Old 09-08-2008   #12
mdost03
Sonic Champion!
Drives: VA STI
I'm not a fan of butt connectors. No matter how hard you crimp them, they always seem to find a way to come apart later.
Old 09-08-2008   #13
ahh ok....ya meh, I dunno. So much vital stuff running through those wires I dunno if I wanna fuk with those. I'd prolly solder them if anything.
Old 09-08-2008   #14
mdost03
Sonic Champion!
Drives: VA STI
Scheides, get a nice soldering iron and just some extra wire looms and practice soldering pieces together. I love soldering stuff nowadays now that I know the right way to go about doing it.
Old 09-08-2008   #15
If you need some help, I am pretty dang good at soldering. I had to shorten, extend, add and remove wires when I did my harness.
lmk.
Old 09-08-2008   #16
I know I know, I can solder, I have done it plenty, but I just have to build up the courage to do this, lots of stuff to break by F'ing up this solder job. I usually have only a handfull of wires to do, I can handle that. This is like 20+ (x2, one solder joint on each end) = 40+ times for me to epic fail.
Old 09-08-2008   #17
When I exteneded some of the wires for my mini-tuck I just used those butt splices that have the heat-shrink on them, so you just have to crimp down the bitt splice, and heat up the heat-shrink, so they're nice and sealed up. After I did that I wrapped it all in electrical tape, and some day I'll get some actual wire loom covering to put it all in. I also have a really nice soldering iron, and if you decide you wanna attack it, let me know, and I'll come give you a hand.
Old 09-08-2008   #18
You're building it up in your head too much, it's really super easy. Just one at a time. Get some flux to make it even easier, but you should have a really easy time since your wires are relatively new and not corroded and green like alot of mine.
Old 09-08-2008   #19
Kevin, where did you get those? I guess it's an option, and I could always do that, make sure all is dandy, then solder later (read: never)...there's just so many wires! Perhaps a winter project...
Old 09-09-2008   #20
mdost03
Sonic Champion!
Drives: VA STI
You can always fix the wiring if you mess up, just cut out where you messed it up and start over.
