Old 11-20-2008   #1
Holset Turbos
So, after a lot of reading, looking, thinking. I more than kinda want a Holset HX35 or 40. Should put my car right where I want it to be, and I like the fact not many people use them. But I want to hear from anyone anything they have heard, read, saw, experienced, or just believe about these Holset's.
One of the most common claims, and main reason people get, is "faster spool than their Mitsu or Garrett counterparts."
Old 11-21-2008   #2
Re: Holset Turbos
What makes a turbo produce boost sooner?
1) polar moment of inertia - probably not all that great on a turbo meant for a 350+ cu in diesel as the designers knew they had a LOT of high temperature exhaust mass to help get that turbine going.
2) a/r ratio. a conical nozzle wrapped into an exh housing. small ratios spool quick and reach choke early. this is likely why these turbos spool fast, if they even do at all.
3) a bazillion other factors
I dont understand the need to get a random redheaded-stepchild turbo to be different.
"wow your car sure is slower than my gt30R car, but props for being different!"
Old 11-21-2008   #3
Re: Holset Turbos
^wow.
Actually everything in the hundreds of pages of Holset experiment users say opposite of your whole post. Who is right? I don't know.
They are proving spool and better top end.
ex. HX40 in mitsu .55AR housing 650whp, HX35 in a bolt on housing 26psi 494/420.
I am thinking about the same thing, in a nutshell if you want 61/35 like power do the HX40, you want something with a spool comparable to a E316G (don't know how much I believe this) but with flow better than a 50 trim do a HX35.
You have options for .55AR mitsu, BEP T3 .70AR, or stock holset where people have cut the divider (don't know how effective) or are having divided manifolds made.
My choice is HX-35, but being budget minded I might have to pay some $$$ to make it happen. I want it in a bolt on with internal gate.
It would cost me $360ish for the exhaust housing, lines, gasket + holset itself.
I think these turbos are appealing because of the spool/top end, but also because of the durability of a OEM turbo, I am not knocking any other turbo here.
Hope that helps.
Old 11-21-2008   #4
Re: Holset Turbos
Make sure to buy other awesome Bullseye products as well, like those baller V-trims they used to sell.
Old 11-21-2008   #5
Re: Holset Turbos
^Maybe you should try something, last I heard you are still sub-par for power.
Maybe if you weren't on here being a smartass.
Old 11-21-2008   #6
Re: Holset Turbos
There you go, talking shit again.
You calling anyone else a smartass is beyond funny.
My car makes great power for the boost i run Thanks for trying.
Old 11-22-2008   #7
Re: Holset Turbos
Well enjoy the good laugh, ITS THE INTERNET. lol.
Also Kevin, I would say to try it depending on your goals for power and spool.
I know that I would try the HX35 because it supposedly spools quick, comparable to a E316G, one guy made 494/420 on a bolt-on housing at 26psi.
If you want bigger HX40, comparable to the GT35R sized stuff but again in the bolt-on housing it spools faster and has put down 650whp, though the power number i believe was on a stroker.
Old 11-21-2008   #8
iceminion
iceminion's Avatar
Re: Holset Turbos
The V-Trim is absolutely amazing, but I agree, the HX-35 is pretty well suited for the 2.0-2.5L engine range.
I have a buddy who has a Merker XR4Ti 2.3l with a volvo DOHC head and a HX-35....the thing screams!!
building a 3000GT AWD Turbo.
Old 01-11-2009   #9
hippiekiller
hippiekiller's Avatar
Re: Holset Turbos
That's what Colin is running now? Haven't heard anything from him in a while now. His car rocks.
Holset's and BW's both are very intriguing to me. I may have to run one or the other.
hippiekiller is offline   Reply With Quote
Old 11-21-2008   #10
Re: Holset Turbos
People on tuners are shower low 11's on the HX35 and good power in the 400-600 whp range on the 35-40 with the shitty BEP housing. Assuming thats a fact, that isn't that bad?
Old 11-22-2008   #11
Re: Holset Turbos
No one has said anything to prevent me from buying one of these. I can't make up my mind.
Super Bleeder are you only skeptical because you don't know enough about them? Where as we all know about the tried and true turbos. I don't know anything about the Holsets other than what I've read on Tuner's from the small group of people that have them. And they claim and are trying to prove that these aren't just worthless diesel truck turbos...
Old 11-22-2008   #12
Re: Holset Turbos
If the HX 35 has done over 400whp, I'd probably go with that. And I'm sure if I didn't get that power with that turbo, something else is the problem, not the turbo. Setup I was thinking about:
HX35/40 with the .55 A/R BEP housing
FP Race manifold
Ebay external dump o2 modified for tial 38MM
Ceramic coat hot parts
1600cc's
e85
DSMLinkV3
BC 272s
Old 01-13-2009   #13
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: Holset Turbos
FP Race manifold
1600cc's
e85
DSMLinkV3
BC 272s
That would be one badass street setup! You're gonna have to give me a ride when it's done!
-1990 Mitsubishi Cyborg 4WD-
Old 01-13-2009   #14
Re: Holset Turbos
HX40 with the .55 A/R BEP housing
FP Race manifold
Ebay external dump o2 modified for tial 38MM V band wastegate
FIC bluemax 1650cc's
e85
DSMLinkV3
BC 272s
I just need injectors and DSMlink! yay
Old 11-22-2008   #15
Re: Holset Turbos
Sounds like a good plan.
Old 11-30-2008   #16
spoolin d dub
spoolin d dub's Avatar
Drives: 1990 eagle talon tsi awd
Re: Holset Turbos
I know a guy that has had HX-35 with the BEP housing on his VR-4. He has HKS 280 cams and that thing spools like crazy. At part throttle at 10-15mph you can hear how that thing is begging to be pushed, spooling for no reason just waiting for you to hit it. It hits like a 16G.
spoolin d dub is offline   Reply With Quote
Old 12-23-2008   #17
wheelhop
Holset's Sex Bitch
wheelhop's Avatar
Drives: 1990 Eclipse, 1991 Eclipse with a little Holset Sex
Re: Holset Turbos
Is it this guy?
Matt
Bolton Holset H1C w/ external gate, fp2X cams, DSMLink, 3" exhaust, FMIC, water injection
"There is nothing better for man than to eat, drink, and see good for all his hard work." Solomon
wheelhop is offline   Reply With Quote
Old 12-23-2008   #18
iroc_g
Drives: 97 GSX, 95 TSI, 04 Celica TRD
Re: Holset Turbos
I dont have any personal experience yet, but after a month of research, I ordered a 7blade HX-40 with the billet 69lbs/min wheel. Ill be running it in a SS BEP Bolt-on housing.
There are pleanty of real world numbers that justify the claims made about these turbos. And although I am just learning to read compressor maps, they do back up the claims of these individuals.
SleepyDSM: Acccording to what I have read, a HX35 in bolton form will support 450 on pump, so on e85 I dont think you have too many worries. And in a BEP housing, spool claims are around 3700 for 20psi
iroc_g is offline   Reply With Quote
Old 12-23-2008   #19
Re: Holset Turbos
^I plan on running the latter.
Old 01-12-2009   #20
Re: Holset Turbos
eh i said f** it and a bolt on HX40 is in the mail.
