Old 01-25-2009   #1
Batmobile2417
Drives: 92 Talon Work in Progress
Alot of 1g Parts
I am pulling everything off of my setup so I can go bigger!
What I have... The price is to shoot me a reasonable offer!
Evo8 fuel pump
Evo8 injectors
1g head with less than 1000 on rebuild
jdm fmic with piping and bov ( This is small but it works)
2g ehaust manifold
small 16g with little shaft play
2 stock intakes
2 valve covers
a set of gauges( volt, water temp, air to fuel ratio not a wideband, boost, oil pressure)
light wieght crankshaft pulley
Contact me at 651-468-1647
Batmobile2417 is offline   Reply With Quote
Old 01-25-2009   #2
Batmobile2417
Re: Alot of 1g Parts
also everything you need to run ds-map version 2 or purchase version 3
Old 01-25-2009   #3
Great seller; very honest and nice!
Old 01-25-2009   #4
Batmobile2417
Thank You Kracka! And good luck on those Injectors let me know how that goes I would be interested to see how that works out. Nice Car!
Old 01-25-2009   #5
Batmobile2417
I decided I am also going to sell a stock 4g63 block and a stock manual tranny. I would like 350$ for the block with about 80,000 miles on it. I was looking to get 300$ for the tranny. Engine runs good and trans doesn't grind and shifts smooth.
Old 01-26-2009   #6
what condition is the short block in? or is it the long block?
Old 01-26-2009   #7
Batmobile2417
Well it depends on what you want. I bought the short block for 350$ I bought a head for 150$. I barely put any miles on it so if I were to sell every thing together I would hope not to loose money on the deal. It is in good condition. However if I were to pull it I would go through things while it was out (just gaskets and inspection and cleaning) other whise it runs great and I also have some king bearing left over for it as well.
Old 01-26-2009   #8
T is for TURBO
Drives: A car
Pics of the crank pulley
T is for TURBO is offline   Reply With Quote
Old 01-26-2009   #9
Batmobile2417
sorry I dont have a camera at the moment. It just looks like an aluminum crank shaft pulley
Old 01-27-2009   #10
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
Your setup has two of everything? That's a good project. :P
Old 01-28-2009   #11
Shane55113
Now 20% less Racist
Shane55113's Avatar
how much do you want for the 16g?
Old 01-28-2009   #12
Batmobile2417
um i think a 150$ sounds good to me
Old 01-29-2009   #13
slowboy101
slowboy101's Avatar
Drives: 91' Eagle Talon TSI
do you still have a head for sale?
slowboy101 is offline   Reply With Quote
Old 01-29-2009   #14
Batmobile2417
yes i do
Old 01-31-2009   #15
portum89
portum89's Avatar
how much for the evo 8 fuel pump
Old 01-31-2009   #16
Batmobile2417
75 would be a good deal on the fuel pump
