Old 02-17-2009   #1
DSM_brother2
Drives: to the shop
bov block off
what should i use to block off the return hose when i have a aftermarket bov?
Old 02-17-2009   #2
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: bov block off
Are you running a GM maf? Or are you still on the stock maf? If you're still stock then get the proper adapter or bov to recirculate it back into the intake.
-1990 Mitsubishi Cyborg 4WD-
Old 02-17-2009   #3
DSM_brother2
Drives: to the shop
Re: bov block off
i have no idea i just bought it and it came wit a bov. it has a 16g sport turbo so i think it has a dif manifold? i dont know any help would be awesome!!!
Old 02-17-2009   #4
Re: bov block off
Old 02-17-2009   #5
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: bov block off
Oh... The sport turbo comes with a flamidation valve. The block off is on there.
Originally Posted by shoutbox
Old 02-17-2009   #6
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: bov block off
Whaaaaaa??
Old 02-17-2009   #7
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: bov block off
First off, deleting the recirc tube is pointless. The only "good" it does is make the purge louder, and that's only good if you're a ricer. It'll cause the car to run like crap and possibly even die when you shift, and it's almost impossible to completely tune that out.
If anything, the manifold is ported, nothing more. I highly doubt it has a different manifold for a 16G, which is a bolt-on turbo.
Spend your time finding a way to get that tube hooked up as opposed to finding a way to plug the intake hole.
Originally Posted by Trogdor
Old 02-17-2009   #8
DSM_brother2
Drives: to the shop
Re: bov block off
im lost here men. it had a block off but the guy took it off and he didnt give me it. so i need something else to block it off wit?
Old 02-17-2009   #9
Re: bov block off
lol
Old 02-17-2009   #10
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: bov block off
Well, it sounds like the car was previously owned by a ricer. In that case, just put duct tape over the hole and call it good.
Old 02-17-2009   #11
311evo
311evo's Avatar
Re: bov block off
I suppose. But the reality is that the entire car is going to explode no matter what you do.
Personally, I'd replace that tranny, sell the car to cut your losses, then buy something off here that's been well taken care of.
its going to blow up because it wasnt recirculating? allright.. Also, i wasnt aware that effected the tranny.
since it was previously owned by a ricer, shouldnt we give him advice to UN-rice his car? not just add to it..
Old 02-17-2009   #12
DSM_brother2
Drives: to the shop
Re: bov block off
what if i want it to function right? i gotta put the recir hose back into it right
Old 02-17-2009   #13
311evo
311evo's Avatar
Re: bov block off
Yes, do that.
Old 02-17-2009   #14
4seasons69
4seasons69's Avatar
Re: bov block off
the only other way you could get it to function right without recirculating it is if you run a gm maf and a maf-translator. but it's a lot easier to just put the recirc hose back in
Old 02-17-2009   #15
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: bov block off
Old 02-17-2009   #16
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: bov block off
WTF error, then double post?
Old 02-17-2009   #17
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: bov block off
I suppose. But the reality is that the entire car is going to explode no matter what you do, so a temporary fix will be good enough.
All this coming from a guy who likes the rubber fist... I would listen to him 100%!
Old 02-17-2009   #18
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: bov block off
Well, my suggestions have been better than yours. Because I'm pretty sure the flamidation valve came standard on his car, doesn't matter what turbo he's got.
And Jake, I was stating it's going to blow up on the basis that he got it in such a shitty condition.
Old 02-17-2009   #19
DSM_brother2
Drives: to the shop
Re: bov block off
im gonna hopefully get it into good shape. i got alot of time with this car. so i just hope it can last after i put some care into it.
Old 02-17-2009   #20
Re: bov block off
See the hose there from the BOV to the intake tube? Do that.
/thread
