Old 02-18-2009   #1
ManiacMotorsports
TOO MANY PROJECTS!!!
ManiacMotorsports's Avatar
GTA Champion!
Drives: 1991 Eagle Talon TSI/AWD, 1992 TSI/AWD, 1998 Eclipse GSX, 1989 IROC-Z, 1998 Cherokee, and a few more
'98 GSX Buildup...
Ok so last summer I blew the turbo up on my basically stock GSX (at 70,000 none the less, seems odd to me but whatever) So, I took this as a sign that it was time for some major upgrades.... None of this will go in till the roads are salt-free but, here is what I've got so far.
Already Installed...
-50 trim turbo
-1g BOV
-Apexi DP
-Espelir 80mm Cat-back
-K&N intake setup
-The usual pillar gauges
To be installed...
-850cc injectors
-Walbro 255 (Wtf does everyone mean by a rewire on these??)
-DSMlink & Eprom ECU
-Greddy24R FMIC
-Dejon intake pipe
Feel like I'm forgeting something I'll edit if I remember anything....
Need to buy soon...
-Fidanza alum flywheel
-Fidanza 3.2 clutch
So the question is, now mind you I'm pretty much broke right now but i'm wondering what else I would need to get it completely streetable. Also wondering what kind of AWHP i should achieve with this setup.
Other things I think I probably need but wouldn't have to be immediate...
Correct me if i'm wrong...
-Turbo timer
-Boost controller???
-Wideband A/F
Last edited by ManiacMotorsports; 02-18-2009 at 10:39 PM.. Reason: Lack of info...
ManiacMotorsports is offline   Reply With Quote
Old 02-18-2009   #2
Re: '98 GSX Buildup...
Do you have any way to tune it?
I think when you rewire a dsm pump, you actually run new wires all the way to the pump, but a dsm person will have to chime in on that.
A wideband sensor and gauge is a very nice thing to have, but uneccessary if you get it tuned on a dyno.
Old 02-18-2009   #3
ManiacMotorsports
GTA Champion!
I'm gonna have Shane at DB tune it.... so i should be set there.... at the very least they sent out my DSMlink with a rough tune for turbo, injectors, fuel pump and intake setup...
Old 02-18-2009   #4
You're definitely going to need a boost controller if you want to run higher than wastegate pressure. A nice simple manual boost controller is the ticket.
There are plenty of fuel pump rewire how-to write-ups online, but with a 255 pump you probably won't need to with a 50-trim.
Old 02-18-2009   #5
ManiacMotorsports
GTA Champion!
I know I shouldn't even know this seeing as how this was just bolt the turbo on and drive it home, but she pushed 26 with no issue and i'm happy with that so would i need a boost controller?
Old 02-18-2009   #6
ManiacMotorsports
GTA Champion!
Now i'm probably going to sound like a moron...but... so i loaded DSMlink on my crappy free laptop, and i don't understand how to use it....so anyone willing to lead the blind on how to use it any advice is welcome....
Old 02-18-2009   #7
2bar1g
Member
Drives: .
Skip the turbo timer. And definitely get a wideband.
Clutch?
Is your setup going to be on pump gas?
2bar1g is offline   Reply With Quote
Old 02-18-2009   #8
ManiacMotorsports
GTA Champion!
Clutch?
Yes I want to stick to 92 octane....I know the stock clutch isn't gonna last... I liked my Fidanza setup in my 1g fwd so i'll probably do the same thing, Alum flywheel and a fidanza 3.2 kevlar clutch. P.S. I've got a 6 bolt motor sitting in storage for WHEN this motor goes....
Old 02-18-2009   #9
The Link forums are your friend when it comes to using that software.
Old 02-18-2009   #10
ManiacMotorsports
GTA Champion!
Lol ya haven't gotten that far they won't let me join without the chip number and the car is currently sitting at my mom's place and I keep forgetting to check when i'm there....
Old 02-18-2009   #11
ManiacMotorsports
GTA Champion!
Anyone know if there is a difference between a FWD fidanza flywheel and an AWD? they list em as separate part numbers but stock they are interchangeable aren't they?
Old 02-19-2009   #12
They are different.
