Old 02-19-2009   #1
LaunchHard
LaunchHard's Avatar
Vibration starts over 35mph???
I just drove my car for the first time since october, and im getting a vibration that starts at 35mph. Theres no vibration in the steering wheel, i feel it most in the center counsel. It feels like its coming from the rear half of the car. I definetly did not have this problem when i put the car away, and i cant get my car tuned until i figure this out.
My first thought were the tires, but i really am not sure. Any advice is appreciated.
Thanks.
Old 02-19-2009   #2
Re: Vibration starts over 35mph???
Flat spots on tires from sitting...
Old 02-19-2009   #3
polishmafia
Smells like cat poop
polishmafia's Avatar
Thats my guess as well, or the tires need to be balanced.
Old 02-19-2009   #4
Check air pressure too. May sure rear brakes arent sticking as well, that might cause pulsing.
Old 02-19-2009   #5
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Take the tires off the back and put them on the front. Then see if anything changes. I would bet its flat spots on the tires as well..
-1990 Mitsubishi Cyborg 4WD-
Old 02-19-2009   #6
LaunchHard
LaunchHard's Avatar
I was actually gonna do this later today.
I just drove it again, and it comes on hard when its in 4th gear and in vacuum. So this kinda makes me think its not the tires, but im gonna try switchin them around anyway.
Old 02-19-2009   #7
LaunchHard
LaunchHard's Avatar
My jack just went to shit and my little brother has a coupon for a free tire rotation at Tires Plus, but he's out of town til tom afternoon. So im just gonna wait and save myself some messin around.
Ill post the results tom afternoon.
Thanks for the info so far.
Old 02-19-2009   #8
Possibly the carrier bearings for the driveshaft? But I'd say it's more likely that it's in the tires.
Old 02-19-2009   #9
cmspaz
Walls need hugs too
cmspaz's Avatar
In vacuum as in full vacuum, or in vacuum as in just not boosting?
If it's full vacuum, you're engine breaking, and it could be due to the weight shift. Just a thought.
Originally Posted by Trogdor
Old 02-19-2009   #10
LaunchHard
LaunchHard's Avatar
Vacuum as in my foot is off the gas while my car is in gear, primarily 4th and 5th.
Old 02-20-2009   #11
cmspaz
Walls need hugs too
cmspaz's Avatar
That's when I first noticed my front passenger wheel bearing causing vibrations, but if it's doing it as low as 35, there'd be better signs of a bad bearing, like noise. Doesn't hurt to check anyway.
That said, I'd blame something at the front of your car, since that's where the weight is while it's at its worst.
Old 02-19-2009   #12
if it's shaking so much, why are you driving it at all? My guess is tires, but flatspots don't happen from sitting for a few months, my quest sat for two years and it drove with no shaking or anything.
Old 02-19-2009   #13
LaunchHard
LaunchHard's Avatar
Im not driving it all over, i just took it around the block to get a feel for the symptoms.
Old 02-19-2009   #14
SnoEclipse
Drives: 07 Eclipse GT
awd or fwd?
Don't overlook wheel bearings too. Pretty much any weight-bearing part of the car could have settled, flattened, stuck, etc, etc over the past 4 months.
SnoEclipse is offline   Reply With Quote
Old 02-19-2009   #15
LaunchHard
LaunchHard's Avatar
Originally Posted by SnoEclipse View Post
awd or fwd?
Its AWD, and i was considering wheel bearing also, but how do i test those??
Old 02-19-2009   #16
Ever heard of tire kickers? lol. Grab the tire and see if it wiggles when it shouldn't.
Old 02-21-2009   #17
311evo
311evo's Avatar
I also think it would be flat spots, or something with the brakes sticking or bearing(s).
