Old 03-05-2009   #1
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
is a 7 bolt from '93 better than 95+?
I hear that some 93/94 1g's had 7 bolts. Are these mechanically identical to the 2g 7 bolts? As in, still prone to crankwalk?
Style's automotive engineer
Old 03-06-2009   #2
Re: is a 7 bolt from '93 better than 95+?
Not as prone to crank walk as a 2g, but it happens more than a 6 bolt. All 93/94's had a 7 bolt.
Old 03-06-2009   #3
s1ngletracker
Drives: A BMW
Thanks jet!
Old 03-06-2009   #4
Dundars
Drives: 1g DSM
Aren't the 97+ 7 bolts less prone to crankwalk than any of them?
Dundars is offline   Reply With Quote
Old 03-06-2009   #5
iceminion
iceminion's Avatar
-89-92.5 6-bolts had a thrust bearing integrated with the center main bearing.
-92.5-94 7-bolts did not have a thrust bearing, but had 7.8:1 compression pistons.
-95-96 7-bolts were this worst 4g63 ever, no thrust bearings, prone to crank walk
-97-99 7-bolts, had separate thrust bearings, not the same as the 6 bolt, but gave the same type of support.
All 7-bolt engines have under-designed rods. prone to failure.
As I understand it , the late model 7-bolt is a better starting point then the 6 bolt. The crank is much stronger and the main caps are unified by a girtle, much much stronger, the oil pump makes less noise while running.
So...if I were to have a 2G, I would definately look into building up a late model 7-bolt, or have the thrust bearings machined in.
the rods on a 7-bolt are still retarded.
So, until then, factory 6-bolts for me!!!
building a 3000GT AWD Turbo.
Old 03-06-2009   #6
They all crankwalk.
Old 03-06-2009   #7
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
They all crankwalk.
This coming from the guy with a built a 7 bolt motor
Old 03-06-2009   #8
^ Ya but you took out my 6 bolt that walked.
Old 03-06-2009   #9
I have seen multiples of every version of the DSM motors crankwalked.
