Old 03-25-2004   #1
Enes
Enes's Avatar
I heard that lots of fwd guys upgrade their fwd axles to awd one's because they are equal lenghth unlike the other ones?
-E
Old 03-25-2004   #2
JustROLLIN
SpunBearing
JustROLLIN's Avatar
This is true. With equal length half shafts you will have less torque steer with the vehicle. The larger the difference in length, the greater the torque steer. Not really a necessary upgrade until quite a ways down the road. In MY opinion.
Old 03-25-2004   #3
Is this possible on 2G FWD's?
Old 03-26-2004   #4
-E
I wouldn't exactly say equal length. It simply uses a split axle with a carrier bearing. Some people say they work well, others say theres no difference. 2G's should be the same as 1G's since they more or less have the same motor and tranny layout.
Old 03-26-2004   #5
I know that 1G axles will not work in a 2G car. You would have to get some custom axles built. I sold my '94 tranny to a kid with a '95 who was sure it would work just fine (disregarded what I told him) and he had to have Raxles make him up some custom ones. I had to do the same for the '91 tranny to work in my '94.
Old 03-27-2004   #6
I meant the same idea of swapping AWD axles into a FWD, not that 1G and 2G axles are the same. I'm guessing 2G AWD axles will fit on a 2G FWD.
Old 03-27-2004   #7
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
I am still split on this debate. Granted the "mid" axle is rigidly bolted to the motor, but the length from the tranny to the wheel is still the same. The only thing you've really changed is where it the pivot point of that axle is. To get "true" equal length shafts you would have to have a setup like the old Olds toronado's or the Caddy eldorado's. The tranny would be partially under the engine.
Old 03-27-2004   #8
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
I would never go back to the stock FWD setup! I love the equal lenghth axles, anyone that would like to drive my car to compare, is more than welcome :3gears:
If you do the swap you need to run the AWD oil seal in the tranz, I'm trying to find someon to make the adapter to run the seal. (I have two)
You need to know the spline count of your cv axl.
Take her to the limit!
Old 03-28-2004   #9
Hmmm, that's good to know as well. I've been getting the itch to do a cheapie project, and I just picked up a little Dodge Colt. With the light weight on this thing, even a slightly boosted 14b and a DSM motor would really haul ass. Traction would be an immediate issue. Hmmmm, projects, projects.
Old 03-28-2004   #10
blown_turbo_tsi
Guest
Tournaments Won: 6
Posts: n/a
wasn't there a dodge colt with a 4g63t running 10's on a stock bottom end?
Old 09-29-2009   #11
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
Re: Equal Lenghth Axles
Unreal, you ever find someone that made an adapter so the awd seal would work? I need to find a good used awd axel seal or go to the stealership and also need to find an adapter or at least getto fab an adapter for the seal.
Old 09-29-2009   #12
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
the awd axles are skinnier than the fwd and wont work i dont think
Old 09-29-2009   #13
bertrenolds5
The axels on a 90-92fdw are the same size as the 90-99 awd axel. 93-94 fwd's can't do it wecause the axels are bigger but my 91fwd can becuase they are the same size. I have the intermediate shaft but I need to know about the spacer to make the awd seal fit the drivers side of my fwd tranny.
I could have posted buy I searched and found this so I thought I would keep it alive.
Old 09-29-2009   #14
Constant_Project21
Constant_Project21's Avatar
Drives: E36
nothing like bumping up a 5 year old topic lmao
