Old 03-23-2009   #1
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
CV question
I need to replace the passengers CV, as its clunking a little... I Replaced the tie rod ends this weekend, but it still clunks a little on the right side. Might be a dumb question .. but, do I need a special CV joint due to the 6 Bolt swap in a 2GB.
Old 03-23-2009   #2
Re: CV question
Get the correct shaft for your car/transmission; the engine doesn't matter.
Old 03-23-2009   #3
Re: CV question
Yea you're transmission is still a 2g, that's all that matters. Might be a good time to get new fluid if you haven't done it in awhile, since you'll have to drain it anyway.
Old 03-23-2009   #4
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Re: CV question
Ahh okay now I understand.... I wasn't thinking about it clearly.. Just had redline not that long ago when MAP put my new clutch in, but new fulid anyhow... if i gotta drain it. thanks for the advice.
Old 03-23-2009   #5
Re: CV question
You shouldn't have to drain it. Just be quick when you pop the old axle out, and put the new axle in. It will drain a little bit out, but if you're quick enough you won't lose enough to make a difference.
Old 03-23-2009   #6
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Re: CV question
Cool! Good to know! Will be my next purchase then.. right after I go on ECM tuning to order my LINK!!!!! Woot Woot I'm gonna do it... Now I just need to learn how to use it.
Old 03-23-2009   #7
Re: CV question
Haha, I didn't even think about doing that. I guess if you're really quick you might just lose an ounce or two.
Old 03-23-2009   #8
Re: CV question
I had to change out my front passenger axle last summer, and I only lost a couple teaspoons.
