Old 04-04-2009   #1
santa
Boost Spike
santa's Avatar
Progress since last year
I put the car on the dyno last fall up at MAP. It did pretty good for 20psi. Hoping to run around 35psi in a few weeks. Then I will head back to the rollers. Fuel (E85) is limiting me to 20psi (need another fuel pump).
Old 04-04-2009   #2
Re: Progress since last year
Not shabby buddy! What pumps you running? Might I suggest what I got!?
-A. Swift
Old 04-04-2009   #3
santa
Boost Spike
santa's Avatar
I was most likely going to throw another wally in it. I would rather not listen to a big external pump all the time while I drive. I can't even hear the current 255 in there. I also considered the bocsh 044 pump as well. What pump's do you have?
Old 04-04-2009   #4
twin wally 310's..
-A. Swift
Old 04-04-2009   #5
santa
Boost Spike
santa's Avatar
I'll have to look into that.
Old 04-04-2009   #6
twin 310s unneeded. swifty just has them so he can talk shit, like he is gonna break 800 or even touch 1000whp the 310s are capable of.
About time kevin, can't wait.
Old 04-04-2009   #7
talk shit on having fuel pumps? Sorry, I don't like running out of fuel. Most run out of pump before they even run out of injector. capable on what gas? saying these 310's are not needed, is like saying those twin aero 1k's are not needed on the FDSM...geez.
-A. Swift
Old 04-04-2009   #8
-A. Swift
Trying to put a race car together but being a hack? Sorry but my cars run and I don't remember you ever having to worry about fuel esp. at 500whp hell you would barely outrun 1 310 at 500whp and thats if you did it at DB.
Old 04-04-2009   #9
santa
Boost Spike
santa's Avatar
The car is down for a week or two until I can get some tires put on it. My left rear tire was flate this mornging. The side wall is really cracked. Its time for some new rubber... Anyone got something?? 225 50 r16 or 245 45 r16??? lol
Old 04-04-2009   #10
meh...It's called planning ahead.
-A. Swift
Old 04-04-2009   #11
santa
Boost Spike
santa's Avatar
Now childeren settle down. lol! I'm still open to ideas on fuel pumps. I considered the new fuel lab brushless pumps but idk if I want to do a external pump
Old 04-04-2009   #12
I'd go with an oem pump, like the bosche or one of the ford choices.
Old 04-05-2009   #13
I run a bosch -044 and it isn't all that noisy for an external. You can hear it when you turn the car on before it is started, but while running you can't hear too much and I have zero sound deadening back there right now and even a few holes where I ripped the bracing out from back there in prep for the cage and the basketball sized hole for fuel cell access.
Old 04-05-2009   #14
I vote twin 255's in the tank. Why not?
Old 04-05-2009   #15
santa
Boost Spike
santa's Avatar
Hmmm decisions to make..... LOL.
Old 04-05-2009   #16
Bosch in tank.
Old 04-06-2009   #17
santa
Boost Spike
santa's Avatar
Bosch in tank.
that's a good possibilty as well!!
Old 04-06-2009   #18
So you gonna spill the beans on your setup?
Old 04-11-2009   #19
santa
Boost Spike
santa's Avatar
Sure why not....I'm bored at work right now
Engine:
2.3 stroker
Malhe 9.5:1 pistons
MAP ultimate duity rods (1000+hp ones)
balance shaft elim.
ported oil pump
acl race bearings
arp main studs
arp H11/L19 head studs
Mitsu metal h/g
Super tech dual valve springs
Manley Titanium Retainers
Crower 415 race cams (the big boys)
Ported head
1mm over sized Ferrea valves
Motors by gosh did my valve job (all the machine work) and cut the valve seats to blend into the head (awesome flow!!)
Setup:
PTE 6776H turbocharger with a .58 ar exhaust housing.
obx ram horn exhaust manifold lol...
full 3.5 inch exhaust
dsm link w/1600cc injectors
AFPR w/ cool B&M gauge lol...Ghetto...
just one wally 255hp in tank (soon to be joined by another one)
act exact flywheel w/2600pp and a street disk(hoping to go up to a twin disk soon as well.)
Mishumotor aluminum race radiator
xspower front mount 28x12x4 core with full 3 inch intercooler piping
tial 50mm bov, and 38mm wastegate
FP 4 inch intake pipe
p/s a/c and all the extras with those two systems are now all gone.
urithane motor mounts.
welded center diff (Thanks Kyle at MAP)
Tien springs on stock struts
FD wheels (planning on buying Jets 555r nitos if he will send me a pic
Big brake upgrade with Rotor Pros all the way around and Hawk hps pads
Pro sport oil pressure, and water temp gauges
Stewart Warner 40psi boost gauge
Battery has been relocated to the trunk
Upgrades needed to go past the 518awhp mark:
MAP twin disk clutch setup
Fuel pumps and lines need to be done
I've had the car 4 years now, and those of you the know me. I beat the shit out of the car all the time. I've launched the crap out of it and it keeps coming back for more.
All this has been done on the original 3 bolt that I got the car with.... It has got to be the best 3 bolt EVER!!!!!! I've currently got a 4 bolt waiting to go in... Just waiting on the 3 bolt to crap out of it.
Heres a old picture from last summer of the engine bay.
I know my BOV is in the wrong spot
Old 04-06-2009   #20
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
how many lbs of vtec?
'04 Honda Ricer: stock
