Old 04-23-2009   #1
TwoTalons
Old & Grumpy
TwoTalons's Avatar
Drives: 1992 Eagle Talon TSi AWD
1G Roll Bar
Kirk Racing Products bolt in 4 point roll bar for 1G DSMs. 1.75" x .120" DOM. Excellent condition.
$220
TwoTalons is offline   Reply With Quote
Old 04-23-2009   #2
Re: 1G Roll Bar
do you have to remove the rear interior for this
Old 04-23-2009   #3
TwoTalons
Old & Grumpy
TwoTalons's Avatar
Re: 1G Roll Bar
I don't think so but I can't say for sure. Never installed it. I've had it for a few years. The guy I bought it from had his interior removed but he was racing the car.
Old 04-23-2009   #4
Re: 1G Roll Bar
So could you just add door bars to this to make it an NHRA legal 6 point? Or would you have to weld it in also?
Old 04-25-2009   #5
TwoTalons
Old & Grumpy
TwoTalons's Avatar
Re: 1G Roll Bar
Wish I could help but I know nothing about NHRA rules. Don't see why it couldn't be modified to make it legal though.
The guy was road racing his car. Never ran it on the drag strip as fas as I know.
Old 04-24-2009   #6
Re: 1G Roll Bar
I don't think it can be made NHRA legal considering some of the tubes bolt together.
Old 04-24-2009   #7
Re: 1G Roll Bar
what if once you installed it you welded those tubes together
Old 04-24-2009   #8
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
Re: 1G Roll Bar
I believe plate dimensions are off too just from looking.
Old 04-24-2009   #9
Re: 1G Roll Bar
+1, The plates need to be 6"x6" and those look rectangular. It would still be a nice kit for someone to run with on the streets though.
Old 04-24-2009   #10
turboimports
Re: 1G Roll Bar
Looking for anything? Maybe trades?
Old 04-25-2009   #11
TwoTalons
Old & Grumpy
TwoTalons's Avatar
Re: 1G Roll Bar
Need a good short block. Preferably a 2.3/2.4.
Old 04-24-2009   #12
Re: 1G Roll Bar
pm'd
Old 04-25-2009   #13
Re: 1G Roll Bar
for it to be legal, the cage MUST be welded. Bolt-in cages do not work.
Old 04-29-2009   #14
Re: 1G Roll Bar
That's not my understanding, unless something has changed from 08 to 09
This is taken right out of section 4:10 of the 2008 NHRA Rule Book:
Unibody cars with stock floor and firewall (wheeltubs
permitted) may attach roll bar with 6-inch x 6-inch x .125-inch
steel plates on top and bottom of floor bolted together with at
least four 3/8-inch bolts and nuts
Old 04-29-2009   #15
Re: 1G Roll Bar
sold thanks keith
Old 04-29-2009   #16
TwoTalons
Old & Grumpy
TwoTalons's Avatar
Re: 1G Roll Bar
sold thanks keith
Thank you!
Old 04-29-2009   #17
Re: 1G Roll Bar
I think the diameter and wall thickness is a bit light for NHRA as well, I can't remember anymore. I know that you need larger diameter tubing when using mild steel than the autocross guys use.
